Results 1 to 11 of 11
    angry english's Avatar
    Posts
    Global Posts
    554 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My old launch white Nexus 5 had a really loose power button and volume rocker, you could literally move them around in the cut outs. The new black one I have does not have this issue, everything is tight, no rattles no nothing.
    I know manufacturing techniques become easier after a while but I'm quite surprised.
    Or is it a case of the black Nexus 5 was always this way and it was just an issue with the white one?
    Not putting the phone down at all, was just something I noticed the very instant I first turned on this black N5
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,127 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Build quality difference between black and white, or sloppy launch devices?
    It was a known issue they modified, along with the speaker grilles.
    http://www.phonearena.com/news/Nexus...uttons_id50321
  3. #3
    win465's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    Nexus 5 gets a hardware revision, currently shipping with new speaker grill and fixed buttons
    Well they did fix the buttons but i dont think they fixed the speaker holes. I just got the red nexus 5 and i still think it has the small speaker holes.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    78,127 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    How certain are you about that? From the article, the difference in grille size doesn't seem that pronounced. Are you able to compare your N5 with others?
  5. #5
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,273 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a white one from launch and no loose buttons or other flaws.
    Sent from my LG-LG870 using Tapatalk 2
  6. #6
    J00P24's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by win465 View Post
    I just got my red nexus 5, volume seems OK but the power is a bit loose in there (not so bad that I'd return it). Also I did notice smaller speaker holes.
    One small thing that I didn't like was that they used the same old nexus 4 charging cable which you'd have to turn upside down to plug in.
    Posts
    Global Posts
    554 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for that, after losing my launch day white nexus 5 I kinda stopped following it due to being absolutely gutted it went down a drain lol
  8. #8
    srkmagnus's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by mrsmumbles View Post
    I think the issues are more pronounced on some devices. It's definitely there.
  9. #9
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,273 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by srkmagnus View Post
    I must have been unusually lucky.
    Sent from my Nexus 5 using Tapatalk 2
  10. #10
    win465's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well actually i think i read that an LG representative denied the new hardware revision on the nexus 5. She said they hadn't changed anything on the nexus 5.
  11. Thread Author  Thread Author    #11
    Posts
    Global Posts
    554 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They have definitely have changed something as like I said in the 1sr post my newer black N5 had none of the issues that my white one did regarding build quality
  1. It's alive.
    By Xingularity in forum AT&T Galaxy Note 2
    Last Post: 02-25-2014, 03:41 AM
  2. apps - Google play for the task manager and usage monitor
    By Avinash Nag in forum Android 4.4 KitKat
    Last Post: 02-08-2014, 11:35 PM
  3. G2 Stuck at HTC screen and eMMC read error - Please Help!
    By archos in forum G2 Rooting, ROMs, and Hacks
    Last Post: 02-08-2014, 11:28 PM
  4. Replies: 1
    Last Post: 02-08-2014, 11:19 PM
  5. Backup for apps and all of my settings?
    By dandrew68 in forum HTC One M7
    Last Post: 02-08-2014, 10:23 PM
