Results 1 to 7 of 7
    Nicat Kerimov's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Problem of the Nexus 5
    My device Nexus 5 16 gb with android 4.4.2kitkat all stock.The problem is that the phone itself is locked in any application such as now when I write a message has to press several times to unlock. Please do a full reset. And it worked fine but when put a couple of programs namely program premium widgets then the phone started again blocked.Than you in advance!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Problem of the Nexus 5
    Welcome to the forums.
    Does the problem seem connected with Premium Widgets?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    not because the problem persists even after I uninstalled the program, I also flash stock, but now it happens when I connect a USB flash drive with OTG.
  4. #4
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    There must be something up with your apps. I would do another reset and slowly add your apps back. 2 or 3 at a time for a day or two, to narrow down which ones are causing problems.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried everything but it does not help.
  6. #6
    Chetan2b's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having 32gb Nexus 5. Day dream option is not working for some reason. Can somebody help me out?
    "Settings"
    Sleep: after 30 secs of inactivity
    Automatically lock after 2 mins
    Daydream: On
    In case: enabled widgets
    Daydream: charging, docked, either. Tried all three options. It's working while charging but not while docked.
    Used Dashclock and normal clock as well. It works while charging but not normally. (It's not working on daydream when docked.)
  7. #7
    jj14x's Avatar
    Posts
    Global Posts
    1,028 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by Nicat Kerimov View Post
    so, after you performed factory reset, the problem started again (even before you added any user apps)??
    or did it start after adding a few apps? (if so, which ones?)
  1. Galaxy Tab Pro 8.4: My review after one week of use
    By VolMan37421 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 11-25-2014, 01:55 PM
  2. What happened to the ink and little sun unlock effects after Kit Kat?
    By MannyZ28 in forum Sprint Samsung Galaxy Note 3
    Last Post: 04-21-2014, 05:03 PM
  3. HP Print Services Plug-In on Nexus 5
    By David Lessnau in forum Google Nexus 5
    Last Post: 02-25-2014, 11:55 AM
  4. Lighten up the phone app
    By xweb10 in forum Motorola Droid MAXX
    Last Post: 02-22-2014, 12:23 PM
  5. Nexus 5 vs Moto x
    By kuziwk in forum Google Nexus 5
    Last Post: 02-21-2014, 11:37 AM
