1. reneeh63's Avatar
    I use a wireless charger at home with my Nexus 5 but when I travel I'd like to use the Nexus 7 charger for both my phone and tablet. Will I "burn up" my Nexus 5?
    02-23-2014 09:07 AM
  2. patruns's Avatar
    You are fine. I have a Nexus 10, Nexus 7 and a Nexus 5 and I grab whatever charger is on top in the drawer.
    02-23-2014 09:15 AM
  3. bjrosen's Avatar
    USB charging is a standard, you can use any USB charger with any USB compatible phone. There are some chargers that are designed to be used with iPhones that support a non-standard protocol that speeds up the charging of iPhones. With older versions of Android these chargers performed poorly, however as of 4.2 or thereabouts Google figured out what they were doing and now those chargers will also work at full rate with Android phones.
    02-23-2014 10:44 AM
  4. reneeh63's Avatar
    Thanks guys!
    02-23-2014 05:35 PM
  5. euanpne's Avatar
    Along the same vein as this thread, i can only find chargers on eBay that are 2 meters long!
    Do shorter ones exist, or are they all monsters?
    02-26-2014 09:52 PM
  6. ffejjj's Avatar
    2 meters, that's easy to long. Would take forever to charge
    Sent from my EVO using AC Forums mobile app
    02-27-2014 12:24 AM
  7. euanpne's Avatar
    Yeah i managed to find a 1 metre one, so will go with that.
    03-03-2014 02:04 AM
  8. patruns's Avatar
    A 2 meter cable will not charge any slower than a 1 meter cable if it is of sufficient gauge. There is not a lot of amps running through it to cause much worry.
    03-03-2014 09:14 AM
  9. jj14x's Avatar
    Well, not exactly. While you can use any USB charger with any USB compatible phone, chargers may have different current output. If you try to charge the N5 with a 500mAH charger, it will slow much slower than it would with the OEM charger
    An issue with cables too - some USB cables have the data pins shorted, and some don't. If the pins are shorted, it will permit faster charging.
    03-03-2014 09:21 AM
  10. JeffDenver's Avatar
    Some chargers are higher capacity than others. Thats why tablets charge a lot slower (if at all) with phone chargers. But they are completely interchangeable. There is no way to fry a phone using a tablet charger.
    03-03-2014 09:29 AM
  1. Dont know how to disable keyboard vibration on Alcatel One Touch M Pop OT-5020X
    By shackattack97 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-08-2017, 04:59 AM
  2. Girls with the Note 3?
    By jelliebean82 in forum Samsung Galaxy Note 3
    Last Post: 03-07-2014, 10:06 AM
  3. Charging N4 issue
    By jc0187 in forum Google Nexus 4
    Last Post: 02-23-2014, 11:16 PM
  4. LG and Google working on Nexus watch (due in June)
    By tr-1 in forum Rumored Devices Lounge
    Last Post: 02-23-2014, 09:45 AM
  5. Nexus 4 ringtones just stopped working.
    By ibabox in forum Google Nexus 4
    Last Post: 02-23-2014, 08:37 AM
