Results 1 to 18 of 18
    Default Nexus 5: Can't access LTE anymore . need help.
    I recently enabled the radios required to use sprint spark on my nexus 5 and now I can't connect to LTE at all. It only connects to 3g. Anyone had this problem.
  2. #2
    Default Re: Can't access LTE anymore . need help.
    Sorry, I'm not familiar with Sprint Spark but under Settings > Network do you have LTE selected?
    If not then it may have changed a setting in the hidden menu. Download an application from the Play Store called LTE OnOff and try and change back to the LTE setting. This application, on many phones, opens the hidden menu.
    Samsung Galaxy Note 3 (Verizon)
  3. #3
    You should check the APN settings against what they should be for Sprint (Google that). Another possibility is a bad SIM - they can get corrupted.
  4. #4
    jj14x's Avatar
    Posts
    Global Posts
    549 Global Posts
    ROM
    Stock
    Quote Originally Posted by smalba View Post
    What band priorities did you set? Did you reset them back (band 25 = priority 1, disable band 26 and 41)?
    Quote Originally Posted by jj14x View Post
    I did set band 26 and 41 and yes I did reset them to see if that would help but I'm still not able to connect to LTE .
    I will have to check the APN and see if that's it. Also in the menu setting it's set to LTE under mobile networks.
  6. #6
    jj14x's Avatar
    Posts
    Global Posts
    549 Global Posts
    ROM
    Stock
    try updating profile and PRL, and then, restart your phone.
    I updated my prl and profile and restarted the phone and it connected to LTE for about 10 seconds and then quickly disconnected and went back to 3g.
  8. #8
    jj14x's Avatar
    Posts
    Global Posts
    549 Global Posts
    ROM
    Stock
    Only thing I can think of is to check for an outage in your area? (yeah, I know, unlikely, but no harm in checking). Try Global (instead of LTE) in settings.
    Only other thing I can think of is to factory reset (ugh). Hopefully others will have better suggestions.
    Thank you. I have tried everything but a factory reset. I just contacted sprint in the Chat online and they weren't able to resolve my issue. They gave me a number to call so I'll try that.
  10. #10
    I had a similar issue, but my was that I didn't switch from 3g to 4G by itself, it would connect to 4G, but only if I forced. So I put everything back reset the phone, set it up to spark again reset it and now it works
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by joselito76 View Post
    You did a full factory reset?
  12. #12
    I hate factory resets as much as anyone here but it sometimes beats hours of troubleshooting.
    Sent from my Nexus 5 using Tapatalk
    -Retired -
    8GB Toshiba Thrive
    AT&T Apple iPhone 3G
    AT&T Samsung Galaxy S2 SGH-i777
    -Current-
    Google Nexus 5 32GB Black
    Apple iPad 4 64GB Black
  13. #13
    Yes factory reset I hate it too, but is one of the ways I resolve my issues lol
  14. #14
    Are you running a custom ROM? Cause I use cataclysm with a smart radio feature, and it disables 4G, uses 3G when I'm using it and uses EDGE when the screens off to save battery. If be surprised if other ROMs didn't have this feature as well... Check in your settings if you have a custom ROM installed.
  15. #15
    You purposely have 4G disabled at all times? That paranoid about battery or what is the reasoning?
  16. Thread Author  Thread Author    #16
    Well after I did the factory reset it seemed to fix the issue. I have been able to access lte . Thanks for everyone's input.
  17. #17
    I didn't think Spark was available for the N5 yet on Sprint, so that might have been the problem.
    Quote Originally Posted by JohnnyBroccoli View Post
    I have it shut off by default and only turn it on when I need it. It can be a HUGE battery saver, particularly if the LTE signal isn't great in your area.
  18. #18
    Default Re: Nexus 5: Can't access LTE anymore . need help.
    LTE actually uses less juice than either 3G or HSPA+ with the same signal numbers. Someone linked an article somewhere on Android Central. If I can find it again I'll throw it up. If you have crappy signal with LTE and great signal with another technology that's a different story. That's your carrier being lazy and the lower the signal the more it tanks on your battery.
    -Retired -
    8GB Toshiba Thrive
    -Current-
  1. Can't Update to Kitkat on AT&T
    By troshs in forum Samsung Galaxy S4
    Last Post: 03-03-2014, 03:11 PM
  2. Help erasing signs of rooted phone
    By Hebaz in forum Verizon LG G2
    Last Post: 02-28-2014, 07:48 PM
  3. A a Avatar help !!
    By Joe Clifford in forum General Help and How To
    Last Post: 02-27-2014, 03:14 PM
  4. Help with KitKat on Nexus 7 2013
    By Lauren Tyler in forum Android 4.4 KitKat
    Last Post: 02-27-2014, 12:02 AM
  5. Help!!! URGENT!!!
    By Sicco Blue in forum General Help and How To
    Last Post: 02-26-2014, 09:47 PM
B
