1. Kage_'s Avatar
    A couple of days ago I noticed a massive battery drain which was confirmed by battery snap app. The stair step pattern indicated an app misbehaving. Looking at my install history from App Install History I noticed that Google search was updated to 3.3.11 and it included some new notification feature for traffic alerts. Anyway I disabled the notifications and the battery drain stopped. So if anyone else is seeing a massive battery drain that has started in the past few days If start there.
    Kage_
    03-15-2014 04:47 PM
  2. Thor20003's Avatar
    Did you just disable all notifications for the app, or is a there a way to disable the traffic info only by going into settings within the app?
    03-15-2014 07:12 PM
  3. Kage_'s Avatar
    The google search shows up the launcher as just Google. Scroll all the way to the bottom, select the 3 dots, Settings, Notifications, and uncheck Show updates from Google Now
    03-15-2014 08:07 PM
  4. Thor20003's Avatar
    I don't use Google now. That must be why I didn't see that option to disable the notification. Thanks
    03-15-2014 11:14 PM
  5. Bront's Avatar
    If search is taking a chunk of your battery, check location services and make sure all your NOW accounts are either On or Off. Mixing On and Off can cause Search to drain your battery getting stuck on the "off" accounts.
    03-16-2014 09:51 AM
  6. srkmagnus's Avatar
    Post a screenshot of your battery usage and lets see what the problem is. Also, take a look through this thread for tips on saving battery: [Guide] Battery Saving Tips
    03-16-2014 09:59 AM
  7. Leo G's Avatar
    Like this? My wife and I have an S4. Mine is fine and hers does this, every day, day in and day out. Hers is 6 months newer than mine. I have them setup the same way, as close as possible. We have different apps on each phone so an exact setup isn't possible.
    I have already done a full reset and the only app I had in there was Battery Monitor Widget and it still had this stair step battery draw. We have gone from 4.1 to 4.3 to 4.4.2 and the draw has stayed. I used several different apps to detect the app that was consuming the battery but never nailed it down. Looked like it was caused by a media server, but she has no music apps or music in the phone.
    It's been perplexing.
    [IMG][/IMG]
    05-31-2014 10:53 AM
  1. Anker batteries for the SGS3
    By AxlMyk in forum Samsung Galaxy S3
    Last Post: 03-17-2014, 04:04 AM
  2. Battery Tip for Dead Zone Users
    By camanokid in forum Google Nexus 5
    Last Post: 03-15-2014, 06:31 PM
  3. Replies: 0
    Last Post: 03-15-2014, 03:06 PM
  4. Help me the app to track battery of a app or process
    By mark997 in forum Health and Fitness
    Last Post: 03-15-2014, 10:29 AM
  5. Galaxy Tab 3: Nice Battery
    By Relgoshan in forum Samsung Galaxy Tab 3
    Last Post: 03-15-2014, 03:41 AM
