Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree7Likes
    Default Nexus 5: Wireless charger not working
    My wireless charging stopped working, KitKat 4.4.2, USB still working anyone knows solution?
  2. #2
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    2,990 Global Posts
    Default Re: Nexus 5 wireless charger not working.
    Quote Originally Posted by mrnaughty View Post
    How do you know it is the phone and not the charger?
  3. #3
    Have you tried moving it around on the pad, to make sure you aren't missing the sweet spot? Also, do you have any other devices that can wirelessly charge, like a Nexus 7? It's hard to tell right now if it's your phone or the pad that's causing the problem.
    Your phone doesn't have a thick case on, does it?
    I got Spigen slim case, and yes, I tried to charge without case. To test charger I did test with Nexus 4 and it did work.
    Is it hardware, software or firmware issue?
  6. #6
    Try rebooting the phone, and see if it works then.
  7. #7
    Gerryinbc's Avatar
    Posts
    Global Posts
    35 Global Posts
    Have you had the back of the phone off for any reason? If you do not put it back on properly that will cause the wireless charging to stop working.
  8. Thread Author  Thread Author    #8
    Numerous times rebooted and never been taken or attempted to take apart.
  9. #9
    accactg's Avatar
    Posts
    Global Posts
    94 Global Posts
    Have you tried with other wireless charger?
  10. Thread Author  Thread Author    #10
    No I did not as I have only one charger. Tried Nexus4 on same charger and it works.
    Sent from my Nexus 5 using Tapatalk
  11. #11
    I tried posting a link that solves the issue but Andriodcentral wont let me. Anyways trying to give credit where credit is due. If you have removed the back for any reason and the wireless charging doesnt work, press above the S a few cm up and you should hear the charging port pop in and voila! Works like a charm!
  12. #12
    Thumbs up Re: Nexus 5: Wireless charger not working
    The "press above the S" trick fixed the wireless charging issue on my Nexus 5. Thanks!
    Brainerd and brosko like this.
  13. #13
    jj71787's Avatar
    Posts
    Global Posts
    9 Global Posts
    Default Re: Nexus 5: Wireless charger not working
    Sorry to revive an old thread but I got the nexus charger for Christmas. It worked until a week ago. I tried positioning it in different areas around the charger. The magnet makes the screen come on but it is not charging.
    Tried different outlets, some give the red light and some don't but neither works with charging.
  14. #14
    Yep, the "press above the S" worked. Thanks!
  15. #15
    Worked for me, too. However, the contact is not vertically centered. It is 2 cm above the S and over toward the volume buttons. Kinda inline with the headphone jack.
    Alex Clabburn and JLX like this.
  16. #16
    That worked a treat - thanks a mill
  17. #17
    Absolutely amazing fix! Worked for me as well. Love it when stuff it that simple!!
  18. #18
    Quote Originally Posted by JACluvsya View Post
    I signed here just to say that you are my hero and I love you. Thanks mate!
  19. #19
    Quote Originally Posted by crxssi View Post
  20. #20
    Me too. The battery cover has contacts that connect wireless receiver to board. You can lift the board contacts slightly. It worked for me. Check YouTube Nexus 5 dissemble video for wireless receiver contacts. I removed my cover to replace battery and it went t... Up. Good luck
  21. #21
    I had not had my coffee while reading this and I was wondering why pressing about the 'S' on the keyboard would help. Sip of coffee later and a light bulb moment, you meant the 'S' on the back. Pressed, clicked, worked!
    Thank you very much for this solution
  22. #22
    Great simple solution! Worked like a charm for me. Thanks for posting this
  23. #23
    Yes, lifting the connectors helped me. i used staple pin to do that. Thank you...
    JLX likes this.
  24. #24
    this is an old thread but u the man!
  25. #25
    Heh. In my case, I was using a mini-usb cable plugged in to either my PC or a Google-supplied power adapter (not for the charger). The red LED was lighting on the wireless charger, which I never noticed before. This indicates insufficient power to the charger. Didn't see this mentioned yet, so here it is.
  1. New Nexus 7 owner
    By dwat191 in forum Introductions
    Last Post: 03-31-2014, 11:20 AM
  2. Tab Pro 8.4 vs Nexus 8
    By roblox84 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 03-30-2014, 04:02 PM
  3. Nexus 7 2013 16gb
    By dt81 in forum Marketplace Archive
    Last Post: 03-30-2014, 03:25 PM
  4. slide to answer, not sliding.
    By Hairdo771 in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 03-30-2014, 02:16 AM
  5. Nexus 4 draining battery while charging and in use
    By CMac o in forum Google Nexus 4
    Last Post: 03-29-2014, 07:30 PM
