karimpas7
I had the same problem at 4.4.2 but with no xposed module, but after the update I didn't have any problem again
Yes, I have been having similar issues for maybe 3 weeks. Doesn't happen with every call but phone will ring and can't select to answer it. It is almost as if the phone app has locked up. Also, when hanging up on a call the icon will still show off the hook at times.
Have not found any fixes or workarounds yet
I had this problem,
Check notification settings for 'Dialler'
>Settings >Apps >All.
Scroll down until you find App called 'Dialler' - check that "show notifications" tick box is ticked.
Solution - If Incoming call is not displaying on the screen.
1. Go To Settings
2. Click on Apps
3. Click on Phone
4. Check Show notifications check box. Its have to checked ever.
Me too I am frustrating with this problem that my phone's not alerting or showing nothing when I received a call .I just simply can't answer any phone calls since a 2monthsI have this issue a couple of times where I am getting a incoming call as I can here my ringtone but nothing is displaying on the screen so I can't answer it. Its really weird. anyone else have the same issue?
Sent from my Nexus 5 using Tapatalk
I don't believe this. Just received an awaited important phone call regarding a lawsuit and the first time this has ever happened, I could see the number calling on the top portion of the screen, but the bottom half, where you swipe, was totally black. I couldn't see the green button to answer the call. I tried to press and swipe on the left side where is usually shows up and nothing. UNBELIEVABLE!!
