1. KazKamasa's Avatar
    Hey
    I have the Nexus 5 on for 1 day and 6 hours and then I shut it down when it only had about 10% left of the battery(I had it on airplane mode). The next day it didn't start at all. After 5 hours I was able to to charge the phone. But then the LED light only flash red and the screen is black. I charge it over the night and still the light is flashing red and the phone will not start(charge the Nexus for about 8 hours at the night).
    I did not get any water damage on it, and I hold in the power button for about 10-30 seconds. I tried with holding down the power button and +/- and still it's dead.
    Have any one had the same problem or just now how to solve the problem ?
    Best regards KazKamasa
    05-03-2014 11:09 PM
  2. Shilohcane's Avatar
    It sounds like you got a bad Nexus 5 and you should contact who you got it from and if that is Google then this is their customer service page
    05-03-2014 11:32 PM
  1. CM11 (kitkat 4.4) button LED lights flickering?
    By BadgerVadge907 in forum Android 4.4 KitKat
    Last Post: 03-29-2015, 09:18 PM
  2. Nexus 5 Wobbly/Bent?
    By Paterick in forum Google Nexus 5
    Last Post: 05-05-2014, 12:11 PM
  3. Nexus 5 technical issues
    By Neymar JR in forum Nexus 5 Accessories
    Last Post: 05-04-2014, 11:09 AM
  4. Nexus 7 (Gen 2) Camera stopped working after Kitkat 4.4.2 update
    By Lean Gray in forum Android 4.4 KitKat
    Last Post: 05-03-2014, 06:04 PM
