Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By mobilecrackers
  • 1 Post By ianhanson85
  • 1 Post By jj14x
  • 1 Post By jj14x
    ianhanson85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default battery drain on standby?
    I'm hoping someone can assist me with this- my battery is draining pretty bad on standby. Its dropped about 20 percent in 2 hours. The phone has literally in my pocket with no use. Any suggestions?
  2. #2
    mobilecrackers's Avatar
    Posts
    Global Posts
    538 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery drain on standby?
    Go to recovery then clear cache if that didn't help buy a new battery. I have a galaxy note which live for 5_6 hours
    tonyr6 likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    The battery is not removable on a nexus 5.
  4. #4
    rhea's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock: GNex; dalepl rom
    Which apps are using the battery?
    Sent from my Nexus 7 using Tapatalk
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Does the drain persist after a reboot? Most of the time, this kind of drain is due to a malfunctioning app, and a reboot resets that app to work correctly.
    Posted via Android Central App--please excuse the brevity and any typos!
  6. #6
    tonyr6's Avatar
    Posts
    Global Posts
    738 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mobilecrackers View Post
    Since I did that my standby battery life is great even with location mode turned on. Before that I was getting 5% every hour and having to keep rebooting my phone.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    How do I get to the recovery screen?
  8. #8
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    [GUIDE] Nexus 5 Recovery
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
  9. #9
    Bront's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also, if you haven't, enable ART over Dalvek. Art helps significantly with idle battery consumption.
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am running art currently. I just wiped the cache in recovery. Going to charge up and see if that helps. Thank-you all for the help. I'll post back in a bit with my results.
  11. #11
    RavenSword's Avatar
    Posts
    Global Posts
    2,584 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Isn't there a battery drain bug that's going to be fixed with 4.4.3?
  12. #12
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    That's the camera bug, but other apps can sometimes do this too.
  13. Thread Author  Thread Author    #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Clearing the cache in recovery mode seems to have fixed my issue.
    B. Diddy likes this.
  14. #14
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Great! Just keep your eyes peeled for any recurrence, and look for any patterns of usage that seem to be associated. But most of the time, it's random.
  15. #15
    haris009's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: battery drain on standby?
    Plz plz help me.I am using lg lu6200.today i charged it full (100%).And there no background apps running no wifi on.I used it 0%...but after 10 hours i turn on the screen and battery was 30%......so plz just tell me that i should buy a new battery? bcz there is no other option.I just want to confirm.Thanku...
  16. #16
    jj14x's Avatar
    Posts
    Global Posts
    1,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by haris009 View Post
    You should probably post in the forum for your device instead of the Nexus 5 forum. Also, in your post, please include more details that will let folks review what is going on, and hopefully help you. Try this before you go to sleep:
    1. Charge your phone to 100%
    2. Reboot your phone
      Put your phone aside for the night, and review battery info in the morning. If issue persists,
      • take screen print of battery usage screen (settings/battery),
      • tap on the graph at the top (screen print),
      • back to battery usage screen, tap on the top 2-3 entries below the graph - screen print
    haris009 likes this.
  17. #17
    haris009's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I didnt posted on my device forum bcz my mobile is not so popular...so i think that nobody will reply.......i will these steps.Thank u
  18. #18
    haris009's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey one more thing.i searched my device but there is not name listed of my mobile.I have LG Optimus LU6200.
  19. #19
    jj14x's Avatar
    Posts
    Global Posts
    1,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Good point. You may want to reach out to the board admins asking about it.
    You could also post in the general LG Optimus forums - LG Optimus Series - Android Forums at AndroidCentral.com
  20. #20
    NexusNick123's Avatar
    Posts
    Global Posts
    325 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem clear the cache and in setting go to apps and make sure there are no app running. And also stop apps that you don't use from running in the back. Check the refresh time on all app change then to never helped me so much.
  21. #21
    jj14x's Avatar
    Posts
    Global Posts
    1,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by NexusNick123 View Post
    ay yi yi.... No. that is NOT going to help, unless you have a terribly coded app installed.
    Just search the web for "android task killers" and you'll understand why.
  1. Widget on Home Screen
    By Wintercreek in forum Samsung Galaxy S5
    Last Post: 11-13-2014, 03:19 AM
  2. Battery levels on HTC One M8
    By LCFC Tom in forum HTC One M8
    Last Post: 05-05-2014, 09:23 AM
  3. Batteries.
    By Elcycle17 in forum Samsung Galaxy S3
    Last Post: 05-05-2014, 12:44 AM
  4. Help with blocking annoying App Ads on a Galaxy Note 3 from Bell.
    By Furious1964 in forum General Help and How To
    Last Post: 05-04-2014, 07:11 PM
  5. Zero lemon extended battery for Galaxy S5
    By thoughthalo in forum Samsung Galaxy S5
    Last Post: 05-04-2014, 01:21 PM
