05-16-2017 10:37 AM
48 12
tools
  1. Myra Nethery's Avatar
    I am experiencing the same buzzing/shaking sound. I tried using a magnet and it did stop the shaking. Will buying/installing a new rear camera solve the problem? Or did it work for you at least?
    06-09-2015 09:48 AM
  2. Jdavis69's Avatar
    You're awesome, thanks SO much for your post!! I dropped my HTC one max yesterday afternoon (it was in a protective case but not protective enough evidently), went to take a pic last night and heard the buzzing sound coupled with constant screen shaking. I've had mine for over a year and have taken hundreds of beautiful pics so was super bummed when I realized it wasn't working. Held the phone to my ear with the camera on, listening to the buzz, and moved the magnet around on the back of the phone up by the camera until the buzzing stopped and Voila! No more buzzing or shaking with my camera back to awesome! The magnet is placed at approximately the 8 o'clock position on the camera. You're a genius, thanks again!
    streetmandesign and MayhemJs like this.
    07-15-2015 06:06 PM
  3. ROUSSET's Avatar
    Exactly the same for me !
    First : Buzzing sound, then no more auto focus
    I'm riding motorcycles too, and us my nexus 5 à Gpx Nav system with a ram mount
    08-12-2015 03:19 AM
  4. foxnfrogs's Avatar
    HI from India! Friends, I'm also having the same issue of blurring pictures and camera buzzing sound. Used to travel on bike but always keeps the mobile in my pocket. But it subjects to lot of vibrations (Indian roads). Is the magnet thing working for every1 having this issue? Do i keep it near the cam whenever i want to shoot pictures? When I placed a large magnet over the phone, the sceen went off. HTC cus' care saying to send it back to UK where it was bought to check the problem. This is my 3rd HTC phone and ppl around me know the camera problem n they recommending others not to buy htc.
    09-16-2015 07:48 PM
  5. streetmandesign's Avatar
    Perfect work on HTC One mini, small magnet between the lens and LED light
    02-09-2016 04:43 PM
  6. streetmandesign's Avatar
    3x3 mm neodymium magnet work fantastic
    02-09-2016 04:44 PM
  7. Jay Reen Ress Tapegngan's Avatar
    Do you ride a motorcycle? Use it with it while mounted to it? I have the same issue and I have seen that many people with this issue have mounted them on their motorcycle and now the camera is messed up. I've had mine for 5 days and it's already messed up.\
    I have the same problem with you..i mounted my phone on my motorcycle..first was ok..just a little adjustments to the ISO then it returns to normal..but after i mounted it again then it goes back to the problem, when i try to fix it, it doesnt work anymore..any one have any idea how to fix it?
    02-17-2016 08:25 AM
  8. Jay Reen Ress Tapegngan's Avatar
    What do you mean about magnet?any kind of magnets will do??is it attached externally to the phone or inside the phone?please help me.
    02-17-2016 08:29 AM
  9. Nazirul Aliff's Avatar
    Hi,
    Everything was great with my camera but recently I started to experience major issues:
    When I try to take a picture of close objects or documents, the camera doesn't focus, the camera is trying to focus again and again while making a low "buzzing" sound and gentle vibration.
    When I try to take a picture of the room or a view, it usually able to focus.
    I have tried other camera apps as well, same issue. Does anyone experience this?
    I don't know if it's hardware related or something else.
    Thanks
    SOLUTION!!
    go to settings>apps>camera>force stop
    Then you just restart the phone. Alhamdulillah it works for me, reply me if it works. Thanks!
    02-21-2016 02:20 PM
  10. nadya3101's Avatar
    SOLUTION!!
    Tried to no luck. Maybe I'll have to get a replacement afterall
    (Using LENOVO vibe Z)
    02-26-2016 06:23 AM
  11. mistyblue's Avatar
    never worked for me and driving me mad
    02-26-2016 07:16 AM
  12. Philip Murphy's Avatar
    I had the same problem with my Nexus 5x - not focusing and buzzing noise (esp. when vibrate sensor was triggered). Camera glass of cover had cracked, which I replaced. After this the camera wouldn't focus. I thought that maybe there was something special about the glass that was broken, which the replacement glass didn't have. Nope. The problem actually turned out to be the smallest of shards of glass being wedged within the camera mechanism itself. The camera unit doesn't look like it moves, but to focus it does. The shard of glass was causing the buzzing sound as well. I guess this might be happening to other people e.g. maybe the phone tapping with a wooden spoon is temporarily dislodging whatever is causing the obstruction (same as magnet).
    To remove the cover start at the USB end and make your way around with a thin piece of plastic (a Starbucks cup stopper did it for me, and a drawing pin to remove glass shard :-)) Also, a powerful magnifying glass and lamp will help - camera unit is very small. Be gentle as I'd imagine it's very fragile.
    06-18-2016 05:55 PM
  13. Silver fairy's Avatar
    Ys i also experienced this issue... Can anyone help me.. How to turn off vibration during taking pics...??
    07-02-2016 02:57 PM
  14. jgunslingerj's Avatar
    I recently started bringing my HTC M8 on motorcycle rides. I have a mount on the bars that holds it so I can use the waze app to navigate. All of a sudden my camera doesn't work, I get a buzzing sound slight vibration and blurry image. Has anybody had any luck solving this issue or is returning the phone the only viable option? The selfie camera works fine. Also, the flashlight app causes similar vibrations.:-
    07-24-2016 05:51 PM
  15. philipconrad's Avatar
    I have blackberry passport thats doing the same thing ,I was informed that camera module has to replaced and my front camera works fine.
    09-16-2016 10:24 PM
  16. imnotpicasso's Avatar
    Yes! I've had my HTC 10 for about a year only and it was only after mounting it on my motorcycle that the camera started buzzing just like you describe.
    11-01-2016 04:25 PM
  17. imnotpicasso's Avatar
    I mounted my phone unto my motorcycle and now i have the same problem :/
    11-02-2016 03:21 PM
  18. iqbal Hossain5's Avatar
    Hi,
    Thanks
    I am also getting same Problem please fix. .
    11-08-2016 06:32 PM
  19. Apbatch's Avatar
    Hi,
    Thanks
    I have must experienced the same thing and am unsure what to do. Does anyone know how to fix it? Thanks
    12-02-2016 11:40 AM
  20. mdgg's Avatar
    I am having the same problem. Everything was fine an now the buzzing an focus problem. I called HTC. Theyn claim no responsibility and they said they have never recorded this problem. The call center gave me the corporate number and they anwer with a recorded claiming they will call back. NO CALL! I would recommend everyone stay away from this company.
    01-19-2017 05:30 PM
  21. B. Diddy's Avatar
    Welcome to Android Central! I assume you're referring to the previous post about the HTC 10 (although this thread is in the Nexus 5 forum). How old is the phone? Is it still under warranty? If so, did you request a warranty repair when you were on the phone with HTC? It shouldn't matter if they've never heard of the problem. You should still be able to send them your phone, and they'll evaluate it. Of course, the problem there is if they determine that there is no problem, or if they determine that it was likely due to damage rather than defect, then they will either return it to you unfixed, or ask you if you want to pay for the repair.
    01-19-2017 07:36 PM
  22. Pieter Nemegeer's Avatar
    i have the same issue with my nexus 5
    02-03-2017 01:14 AM
  23. MayhemJs's Avatar
    I have the exact same problem. My camera doesn't focus and is wavy and blurry. It has the annoying buzzing sound as well.. I couldn't solve it, did you get it solved? Please help.
    05-16-2017 10:37 AM
48 12
  1. SM-G900H (Exynos) users - Do any 64GB cards work for you?
    By 1AvgUser in forum Samsung Galaxy S5
    Last Post: 06-09-2014, 04:13 PM
  2. how does the notifications work...
    By iamdustin24 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-08-2014, 12:50 AM
  3. Replies: 1
    Last Post: 05-06-2014, 10:56 PM
  4. Google Calendar is not Syncing.
    By mawil1013 in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-06-2014, 08:46 PM
