1. drathos's Avatar
    I'm not sure what happened, but my battery life today has been crap. Of late, my battery has made it through a day with a good amount of battery left (something like 50% to 60% remaining) after 10 to 11 hours off the charger and no wi-fi (turned on, but not connected) with light to moderate use (probably 1 to 2 hours of screen on time).
    Today, however, I noticed in the early afternoon that I was down around 40% left. When I checked, the only things listed for battery use were "Android OS" at 93% and "Screen" at 2%. Obviously something was off, so I rebooted my phone. When it was time to head home (6ish) battery remaining was in the teens (14% I believe). Battery use info was still the same. I've used other apps today (Falcon Pro, Chrome, Gmail, WeatherBug, and a few others I can't recall offhand) but they don't show in the battery use list like normal.
    Does anyone have any suggestions or solutions? Strange battery use-screenshot_2014-05-12-20-38-26.jpgStrange battery use-screenshot_2014-05-12-20-41-53.jpgStrange battery use-screenshot_2014-05-12-20-42-05.jpg
    05-12-2014 08:01 PM
  2. maverick7526's Avatar
    If a reboot does not work. Run the battery completely flat. Sometimes this has happened to me and I did that, and it leveled out, and went back to normal.
    Posted via NSA Spy Van 37...... Free candy??
    drathos likes this.
    05-12-2014 08:33 PM
  3. Igneel's Avatar
    My normal battery life was 40% after 10 hours. Is this normal or is this a sign of a problem?
    05-13-2014 09:21 AM
  4. drathos's Avatar
    Thanks. This seems to have worked. After 3.5 hours, I'm only down 9% and I've got about a dozen apps listed in the battery usage.
    05-13-2014 10:36 AM
  5. drathos's Avatar
    Battery life varies with different conditions. I've had days where mine's mostly dead after 5 or 6 hours due to heavy use or lack of any cell/wifi signal. It helps to look at the Battery Use screen to figure out where any drain might be. When my signal is weak or non-existant, "Cell standby" can be my biggest drain.
    The issue I posted about was with the same conditions as the previous days I'd mentioned, but drastically different battery life and usage list.
    05-13-2014 10:45 AM
  6. mclasser's Avatar
    I've had experiences with my Note 10.1 and old NS4G where the OS was using a hefty portion of the battery (although not nearly as high as yours). A restart and periodic reset fixed the issue.
    Hasn't happened on my Nexus 5, yet.
    05-13-2014 12:12 PM
  7. Igneel's Avatar
    Now it's 30% after 8-9 hours...
    05-15-2014 09:24 AM
  1. Samsung Link Platform draining battery
    By smooth4lyfe in forum Samsung Galaxy S5
    Last Post: 01-16-2016, 12:24 AM
  2. my Samsung galaxy s3 battery drains very faster than expected
    By amoledsucks in forum Samsung Galaxy S3
    Last Post: 01-30-2015, 07:36 AM
  3. Stick with Anker extended battery or go to Zerolemon?
    By mchi5 in forum Samsung Galaxy Note 3
    Last Post: 05-14-2014, 02:32 PM
  4. Battery life degradation
    By thepurpleturtle in forum HTC One M8
    Last Post: 05-12-2014, 01:46 PM
  5. galaxy gear draining my note 3 battery
    By amdroidboi in forum Samsung Galaxy Gear
    Last Post: 05-12-2014, 11:28 AM
