1. coldtone's Avatar
    Hey guys,
    I know alot of you are pros at this so I'll ask my question.
    Is it normal for the Nexus 5 to get hot while charging via a USB car charger? I recently purchased a belkin Car MicroCharger, and the phone gets hot while charging. Could this damage the phone?
    Thanks for the coming advice.
    05-18-2014 03:54 PM
  2. crxssi's Avatar
    Well, "hot" is relative. That said...
    All batteries warm up when being charged. And the faster they are charged means more current and higher temperatures. The phone will charge at various rates, depending on what it will allow and what current is available. It is "normal" for the phone to be up to quite warm when charging. In my experience, quality car chargers (DC) seem to supply more current than most home AC chargers... not sure why, though.
    05-18-2014 06:43 PM
  3. IAmSixNine's Avatar
    One question i have is are you using your phone while charging in the car?
    Keep in mind that charging and using it will always cause it to heat up faster.
    And as crxssi mentioned, hot is a relative term. Try to get the actual battery temp. There are plenty of diagnostic apps and battery apps that will show that info.
    Anything over say 105 degrees is starting to get into the range of not good.
    They are ok operating between 50 and 100 degrees, Fahrenheit.
    05-24-2014 04:17 PM
  4. maverick7526's Avatar
    Hey guys,
    Def don't do what I did. I used my old galaxy nexus as a GPS, and I was charging it in the car. The internal batt temp got to 145 F it would not hold a charge for more than an hour. After a couple of days it leveled out. But the damage was done.
    Posted via NSA Spy Van 37...... Free candy??
    coldtone likes this.
    05-24-2014 05:01 PM
  5. coldtone's Avatar
    No I wasn't using it while it was charging. I subsequently sold the charger. Think I took up the wrong type.
    06-10-2014 08:37 AM
  1. [PROBLEM] Samsung Galaxy Note 10.1 not working if pressing power button
    By msstaki in forum Samsung Galaxy Note Rooting, ROMs, & Hacks
    Last Post: 04-03-2015, 12:35 AM
  2. Can anyone recommend a good, cheap car charger for Note 3?
    By HiMynameisMattyK in forum Samsung Galaxy Note 3
    Last Post: 06-03-2014, 03:16 PM
  3. Sprint Galaxy Note 3: notification problem
    By Losonoso in forum Sprint Samsung Galaxy Note 3
    Last Post: 05-29-2014, 07:53 PM
  4. HTC One USB issues
    By linuxas21 in forum HTC One M7
    Last Post: 05-19-2014, 05:34 PM
  5. Replies: 0
    Last Post: 05-18-2014, 10:54 AM
