1. pratnala's Avatar
    Today I installed Slide Lock for notification management and I am seeing a decreased battery life. Anyone else has similar experiences?
    05-23-2014 08:38 AM
  2. Golfdriver97's Avatar
    Is this the app you have: https://play.google.com/store/apps/d...=com.slidelock
    05-23-2014 08:57 AM
  3. pratnala's Avatar
    Yes
    05-23-2014 09:05 AM
  4. Golfdriver97's Avatar
    Downloaded. I will try it out over the next few days, and see what happens.
    isdaako likes this.
    05-23-2014 09:10 AM
  5. pratnala's Avatar
    Thanks
    05-23-2014 10:28 AM
  6. yubeie's Avatar
    I've been using the app for a few days now and don't notice any major drops in battery life. However.. One thing you can do to prevent any such issues is .. . Disable wake on notification for all the apps except the few that you absolutely need..
    AC@N5
    Golfdriver97 likes this.
    05-24-2014 09:13 AM
  7. Ed Briggs's Avatar
    That's one reason I never install 3rd party launchers, locks, widgets, themes.......and try to stick with time tested apps.
    05-24-2014 07:22 PM
  8. Golfdriver97's Avatar
    I have noticed nothing in regard to excessive drain on my N5. Could the OP post a screenshot of the battery stats, please? Perhaps there is another reason for the drain?
    From a Slim M8 and the AC Forums app.
    05-24-2014 07:49 PM
  9. pratnala's Avatar
    When I went to Settings -> Battery, SlideLock had the highest percentage. I will install it again and then show you
    05-26-2014 12:13 AM
  10. Nir Hason's Avatar
    I had the same problem. Its a great app, very helpful but my battery went from 100% to 80% when the screen was locked in 2 hours and I enabled only 6 apps to send notifications
    05-26-2014 02:16 AM
  11. Golfdriver97's Avatar
    Perhaps the suggestion yubeie made is something to go on. While I did not experience any drain, doesn't mean that it isn't there.
    05-26-2014 10:01 AM
  12. pratnala's Avatar
    Is this normal? My battery definitely ran out sooner than normal days yesterday
    Posted via Android Central App on Nexus 5
    Attached Thumbnails Is Slide Lock a battery hog?-screenshot_2014-05-26-21-07-18.jpg   Is Slide Lock a battery hog?-screenshot_2014-05-26-21-07-27.jpg
    05-27-2014 12:18 AM
  13. Golfdriver97's Avatar
    I don't think that is is bad considering the nature of the app.
    Sent from my One M8 using AC Forums mobile app
    05-27-2014 08:26 AM
  14. pratnala's Avatar
    I didn't have the same experience with Dynamic Notifications which also shows notifications on the lock screen. I didn't like the way it shows them so I removed it. But in that case, it didn't use so much of my battery
    05-28-2014 01:28 AM
  15. Orel Elimelech's Avatar
    It drains the battery on my LG G2.
    I unchecked apps from the list, hopefully it will help.
    08-04-2014 02:35 AM
  16. Brian Low's Avatar
    when i used it i did notice battery drops more often. That didnt stop me from using it though, what stopped me was how buggy it was. Sometimes id wake my phone and it would be the stock wake screen and then cut away to the slidelock lock screen
    08-04-2014 01:52 PM
  1. Battery life help
    By Debo45215 in forum Samsung Galaxy S5
    Last Post: 12-16-2014, 08:45 AM
  2. [NEW][FREE] Space square - stay in the line alternative
    By SneakyBox in forum Android Games
    Last Post: 05-27-2014, 06:42 AM
  3. Thank GOD! A Battery Fix Coming
    By Murph5150 in forum Samsung Galaxy S4
    Last Post: 05-23-2014, 08:40 AM
  4. Is my phone dead FOREVER !!!
    By missteeone in forum Samsung Galaxy Note 2
    Last Post: 05-23-2014, 07:52 AM
