Hello,
I have a brand-new Nexus 5. For some reason, the wifi connection keeps slowing to just less than 2mbps. If I turn the wifi off and on again via the phone settings, the connection always flies back up to around 30mpbs, but only for a short time (maybe around 15 minutes - it is seemingly random). My connection is a very stable fibre optic one and all other devices in my home operate fine, as did my previous phone.
I have tried all of the following options, which I found on a site, but to no avail:
1. Enable Airplane mode then turn off or toggle the Wi-Fi on and off to reset the connection.
2. Reboot the Nexus 5 to refresh the entire system.
3. Switch off the Wi-Fi router for 10 seconds then turn it back on.
4. On the Nexus 5 Settings menu, select Wireless and networks > Wi-Fi > Forget the network the problem then reconnect and entire the right details.
5. Update the firmware of the Wi-Fi router by checking the Web site from your Internet Service Provider's manual.
6. Change the band on your Nexus 5. Go to Settings > Wireless and networks > Wi-Fi > Menu key > Advance > Wi-Fi frequency band > Try 2.4 GHz or 5 GHz only instead of Auto. Uncheck the Avoid Poor Connections as well to improve Wi-Fi connectivity.
If anyone could offer any assistance then it would be really appreciated. I am absolutely impressed by this phone so far but this issue is really not good - it is slowing an otherwise lightning-fast phone down to a grind.
Thanks very much in advance,
Lee
Lee
