04-29-2017 09:12 AM
54 123
tools
  1. Wesley Ken's Avatar
    Its work. thanks bro
    03-06-2017 08:55 PM
  2. anitha5's Avatar
    OK.... You have a couple of options here.
    First... from a powered down state.... hold the up volume and power button for about 10-20 seconds. Then hold the down volume and power button. It SHOULD turn on and go into the backup bootloader screen. The 5 has a secondary, backup bootloader (I learned about this when the Hellscore app borked my primary bootloader when it laid down the Nexus 4 kernel on top of it.. serves me right for trying to save some time).
    If it stays in the bootloader now, at least you can go from there. If it STILL doesn't stay powered on, your toast. Something, probably in the power circuitry, is junk. The Nexus 5 is near impossible to brick because of a software problem. You can recovery from just about EVERYTHING.... well, short of something overwriting the primary AND backup bootloaders. But pretty much anything else can be recovered as long as it isn't something with the hardware.
    If it stays up, from there, go in and clear your cache and reboot. That's might be a shot in the dark.... I'm guessing that your issue isn't just a corrupt cache. Reboot and see if you can get it to stay up. If not... repeat the above to get into the bootloader... do a factory reset.
    Yeah, factory resets suck, but hopefully you loaded a custom recovery when you rooted and have a relatively recent system backup you can fall back on. If you DON'T and got your phone up and running.... LOAD A CUSTOM RECOVERY AND MAKE A BACKUP.
    03-15-2017 03:26 AM
  3. anitha5's Avatar
    your remedy to restart nexus 4 is useful. i tried and succeeded. after 3 years of my phone shutdown. but only thing i had to reset to factory settings erase all data because my phone was encrypted by a password.
    03-15-2017 03:28 AM
  4. bazzycee's Avatar
    Firmly hitting the power button with a spectacle case did the trick....it works, thus I say thanks to androidcentral.com
    04-29-2017 09:12 AM
54 123
  1. Manually turn on Driving Assist
    By kased in forum Moto X (2013)
    Last Post: 06-29-2014, 04:42 PM
  2. Tablet is on wrong screen cannot unlock
    By Illinoisgal43 in forum Ask a Question
    Last Post: 06-29-2014, 11:48 AM
  3. Samsung Galaxy S# Battery will not hold charge
    Last Post: 06-29-2014, 10:33 AM
  4. Recovering deleted photos- HELP! :'(
    By DorStern in forum Ask a Question
    Last Post: 06-29-2014, 09:22 AM
  5. Missed Call Notification On Front Screen
    By gaspower in forum Samsung Galaxy S5
    Last Post: 06-29-2014, 09:17 AM
