Results 1 to 2 of 2
    Hkyoho
    Hkyoho's Avatar
    Guest
    Default Dropped Nexus 5 in water, screen sorta working
    So I dropped my Nexus 5 in some water a few days ago. Put it in rice and it's still functional but parts of the screen don't work. It just so happens this means I cannot answer calls or type with ease. Luckily autocorrect fixes the typing for the most part. However I can't drag to the right to answer incoming calls.
    So my two questions are:
    -Is this likely (cheap/freely) repairable?
    -If not then what is the best alternative?
  2. Best Answer
    It's probably not easily repairable. You could try contacting Google or LG, but chances are that the water damage won't be covered by warranty.
  3. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Dropped Nexus 5 in water, screen sorta working
  1. Nexus 5: 1080p in the YouTube app?
    By glc650 in forum Google Nexus 5
    Last Post: 09-19-2014, 05:31 PM
  2. Htc One M8 white screen pops up
    Last Post: 09-01-2014, 02:53 AM
  3. Can't use unlock effect and ink effect in lock screen settings.
    By peacefulberry in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-03-2014, 10:52 AM
  4. Lock screen too slow to respond
    Last Post: 07-03-2014, 12:14 AM
  5. Screen issue
    By lynnecatalina in forum HTC One M7
    Last Post: 07-02-2014, 11:34 PM
