1. tonyr6's Avatar
    Since T-Mobile offers unlimited streaming for many of the music services like Slacker, DI, Sky.fm that I subscribe to I wonder streaming them on LTE if it uses less battery life than streaming them on WiFi on 5 Ghz?
    07-09-2014 02:25 PM
  2. jj14x's Avatar
    That will likely depend on the signal strength. But from my experience, WiFi seems to use less battery. YMMV
    tonyr6 likes this.
    07-09-2014 03:13 PM
  3. mclasser's Avatar
    +1
    Sent from my Nexus 5 via Android Central App
    07-09-2014 03:33 PM
  4. tonyr6's Avatar
    Thanks. I get 2 to 3 bars on WiFi in another room and on LTE I get 1 to 2 bars.
    07-09-2014 03:39 PM
  5. jj14x's Avatar
    While Android has improved the signal strength indicator considerably since 4.4.3 onwards, I still think you shouldn't trust it entirely for this purpose.
    I'd look at the actual RSRP (in dBm) measurement. On Sprint, I can dial *#*#DEBUG#*#* on the Nexus 5 dialer and look at the LTE engineering section to find out the exact LTE signal strength. RSRP levels for usable signal typically range from about -75 dBm close in to an LTE cell site to -120 dBm at the edge of LTE coverage.
    I think this same check will work on T-mo as well.
    07-09-2014 03:57 PM
  6. LeoRex's Avatar
    A strong WiFi signal sips charge. If the WiFi radio can turn down the power and maintain its connection, it'll have little to no impact on your battery..... conversely, a bad Wifi link will devour your battery. And while the same still holds true with LTE, it'll still use up a charge quicker than a good WiFi link, no matter how strong it is.
    But a good T-M LTE link is like a direct pipe into the internet backbone..... dat speed!. I never get a really good LTE link at my house, but if I did, I would consider dropping off my home WiFi and sticking to LTE... damn the battery hit.
    07-10-2014 04:19 PM
  1. Screen protectors: Necessary or no?
    By Fearless Freep in forum LG G Watch
    Last Post: 07-17-2014, 10:45 PM
  2. Battery life just took a nose dive
    By Still Mostly Harmless in forum Samsung Galaxy S5
    Last Post: 07-16-2014, 07:36 AM
  3. Mail Order or In Store Purchase for LG G3?
    By RicKaysen in forum LG G3
    Last Post: 07-10-2014, 03:53 PM
  4. Nexus 5 WiFi vs. Data Usage
    By clporritt in forum Google Nexus 5
    Last Post: 07-09-2014, 03:12 PM
  5. Nexus 7 battery problem
    Last Post: 07-09-2014, 12:58 PM
