Results 1 to 2 of 2
    GuovaGames's Avatar
    Posts
    Global Posts
    4 Global Posts
    Default [root] need help on system sounds
    What's going on Android Central! (Forget to introduce myself: I am a proud Nexus 5 owner and an Android Developer) I have an issue changing custom system sounds on my rooted Nexus 5.
    For instance I changed (replaced) the keyboard key pressing sound in "/system/media/audio/ui/***.ogg" but once I reboot my phone it does not make any notice at all! I used Audacity to export custom ogg sound effects. If anyone knows what's wrong let me know. I searched everywhere on Google but no help!
  2. #2
    Default Re: [root] need help on system sounds
    Changing the system sounds is something I've been doing for a long time now. Currently I use the 4.3/4.4 ui sounds that I can flash with TWRP or move from storage with Root Explorer. I'm going to guess that the permissions were changed and need to be corrected which is almost always the case when files are moved into the system. You will need to mount the system as R/W (read/write) to change the permissions. In my 2nd screenshot towards the top right you can see the button 'Mount R/O," tapping that button will cycle it from R/O to R/W and back. You will of course need to be rooted to do any of this.
    Attached Thumbnails Attached Thumbnails [root] need help on system sounds-screenshot_2014-07-19-15-34-33.jpg   [root] need help on system sounds-screenshot_2014-07-19-15-36-00.jpg
  1. google nexus 4 not turning on
    Last Post: 03-03-2015, 11:41 PM
  2. please help
    By hjjf in forum Ask a Question
    Last Post: 07-19-2014, 03:56 AM
  3. Internal Storage full HELP
    Last Post: 07-19-2014, 03:46 AM
  4. no registerd network on samsung galaxy s3 mini
    By pauline higgins in forum Software Development and Hacking
    Last Post: 07-19-2014, 01:48 AM
  5. Need help flashing rooted/ROM'd Galaxy S4 back to stock OS
    Last Post: 07-19-2014, 01:32 AM
