Results 1 to 14 of 14
Like Tree1Likes
  • 3 Post By zedorda
  • 1 Post By Gekko
  • 1 Post By macroguy07
    mclasser's Avatar
    Posts
    Global Posts
    122 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Weather widgets that aren't battery hogs
    I'm currently using EZ Weather HD and while it looks nice, it seems to be a battery hog. Can you guys recommend other apps that are visually-pleasing but run lean?
    Sent from my Nexus 5 via Android Central App
  2. #2
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Weather widgets that aren't battery hogs
    ATM I use the "stickmyheadoutthewindow" app and it works but lacks a 4-day forecast. Doesn't seem to effect my battery in the least.
  3. #3
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    1. Fancy Widgets
    2. Arcus Weather
    zedorda likes this.
  4. #4
    PapaGary's Avatar
    Posts
    Global Posts
    827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    1Weather has always worked well for me. Some reviews claim it to be a battery hog but I have not found that to be the case.
  5. #5
    bbycrts's Avatar
    Posts
    Global Posts
    195 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shouldn't any weather widget that allows you to choose the update interval be easy on battery? I use Transparent Weather or something like that because I like the widget's style - I have it set to update once per hour and if I open the app itself (not just the widget). Doesn't seem to have a bad effect on battery life.
  6. #6
    ptkelly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I like Yahoo Weather. I used Accuweather and didn't find is Accu. I don't have a battery problem but I don't know if either is a hog or not.
  7. #7
    PapaGary's Avatar
    Posts
    Global Posts
    827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bbycrts View Post
    That's the way 1Weather works. I have it set to update every fifteen minutes on my Moto X.
    Quote Originally Posted by ptkelly View Post
    I had Accuweather for awhile and dumped it after a week. That was some time ago and I don't remember why.
  8. #8
    kolyan2k's Avatar
    Posts
    Global Posts
    213 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Google Genie widget
  9. #9
    macroguy07's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Weather & Clock Widget Android
    Looks nice, not a battery hog. Various widget sizes and customizable.
    peacefulberry likes this.
  10. #10
    Bront's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been using Weatherbug Elite for ages, and still love it.
  11. #11
    mastrK13's Avatar
    Posts
    Global Posts
    133 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The best for your battery I think is Dashclock widget. It comes with a weather extension but you can install other weather extensions too. Eye in the Sky and atmosHere are great weather apps that have a persistent notification for weather. I kind of like that option as opposed to a normal widget. Neither are hard on your battery and you can choose how often you want them to sync in the background
  12. #12
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No matter which one you pick if you can not control how often the widget updates you will not have much control over battery usage. I have been using Google Now for my weather needs because widgets use more battery no matter which one you pick.
  13. #13
    peacefulberry's Avatar
    Posts
    Global Posts
    970 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Weather&clock widget for me too.
  14. #14
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zedorda View Post
    1. Fancy Widgets
    2. Arcus Weather
    both of the Widgets above allow you to set the update interval. i set both to 30 minutes and have no significant adverse battery life effect.
  1. TIPS to Extend Your Battery Life
    By Three7s in forum Samsung Galaxy S5
    Last Post: 11-28-2014, 01:07 PM
  2. Replies: 7
    Last Post: 07-25-2014, 09:46 AM
  3. After KitKat 4.4 Upgrade - better battery life?
    By Maypo in forum Sony Xperia Tablet Z
    Last Post: 07-24-2014, 06:54 PM
  4. Galaxy s3 battery life question
    Last Post: 07-24-2014, 04:35 PM
  5. L and R tab above battery on verizon note 3...
    By David Thack in forum Ask a Question
    Last Post: 07-24-2014, 04:17 PM
