Results 1 to 6 of 6
Like Tree4Likes
  • 2 Post By B. Diddy
  • 2 Post By belodion
  • 1 Post By John-Smith
    John-Smith's Avatar
    Posts
    Global Posts
    462 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 9.1
    Default So poor signal is a pretty known issue right?
    So I've had my Nexus 5 since about January and hadn't really experienced any problems until..
    In May I started experiencing signal problems. Constantly losing signal, draining battery, no service, etc.
    I figured I would wait until the 4.4.4 update and see if that helps. So, I waited. I reset my N5 completely to factory settings and installed 4.4.4. But I still got the same problems.
    I Thought maybe it was my network, so I went online and checked some forums and fiddled with my APN settings and went around for a few days like that before I changed it back. That didn't work either..
    I then came across several different radios for the Nexus 5. So, I flashed a radio and went around for a couple days with the new radio to see if that would help, I did this with every single US N5 radio (I believe there was 5 or 6). And this didn't help me either.
    I said whatever and I just dealt with the crappy signal for 2 months.
    Then I finally went to the T-Mobile store and told them my story and showed them the screenshots that I take every now and then indicating the loss of service. "No Service - Selected network (T-Mobile) unavailable" "Cell standby 52% - Time without signal 60%" etc..
    They swapped my SIM out and told me that should do the trick.. Well it didn't.
    So I went back online and started doing more in depth searching. Some people said the turn Wi-Fi optimization off (as if that would do anything), some said to set it to 3G only, others suggested a combination of the two plus fiddling with APN settings.. Well I did all of that, and still nothing.
    I then flashed a custom rom thinking that might actually help for some reason.. Well it didn't.
    I've finally come to the realization that it has to be the phone, it must be a hardware problem. I hope I'm wrong though and someone out there has had the same issue as me and solved it.
    Any help is appreciated.
    It just sucks because I really do like this phone, it's an awesome phone aside from this major inconvenience.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: So poor signal is a pretty known issue right?
    Is this only at home, or in various places? If it's only at home, you could ask T-Mobile to give you a signal booster.
    Also, since you have T-Mobile, could it be the network, rather than the phone? I have T-Mobile and I like them, but they're not always the best when it comes to widespread coverage or adequate penetration inside some buildings. You could consider getting a prepaid SIM from AT&T and testing it out--if the signal is much better, then it's a T-Mo problem.
  3. #3
    belodion's Avatar
    Posts
    Global Posts
    19,845 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you tried using the device in different areas and if so is the problem just as bad? In other words, so far as you know it's not just a radio problem in your area because of network changes the carrier may have made those months ago?
    B. Diddy and Laura Knotek like this.
  4. #4
    belodion's Avatar
    Posts
    Global Posts
    19,845 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    (Oops, posted same moment.)
  5. #5
    maxburn's Avatar
    Posts
    Global Posts
    997 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm also not a fan of T-Mobile coverage. Try a GoPhone SIM for a month. In general the phone is a little bit worse than some but it certainly doesn't seem that bad.
    John-Smith's Avatar
    Posts
    Global Posts
    462 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 9.1
    Quote Originally Posted by B. Diddy View Post
    It is in various places everywhere I go, including some parts of my 1BR apartment. I think I am going to do what you said and try out straight talk for a month and see what's up.
    B. Diddy likes this.
  1. Replies: 18
    Last Post: 08-06-2014, 04:22 PM
  2. phone isnt showing signal
    Last Post: 08-02-2014, 05:59 PM
  3. Samsung galaxy s4 Signal drop
    Last Post: 08-02-2014, 05:08 PM
  4. moto x touch less control issues
    By RPoetzman in forum Ask a Question
    Last Post: 08-02-2014, 02:27 PM
  5. lg optimus f3 t mobile memory issue
    By Unregistered in forum Ask a Question
    Last Post: 08-02-2014, 01:34 PM
