1. Bilal ArQob's Avatar
    - My Nexus 5 screen lock off by it self while I using the device! after 1 or 2 sec .. (not always)
    - The music player ( SoundCloud, TTPod .. etc ) move to the next song auto without the song finish!
    08-04-2014 06:37 AM
  2. Buddy1969's Avatar
    What exactly are you doing when Screen Lock activates itself? Did you try to turn off the screen locking in the settings? What does it do then?
    Which music player are you using?
    Do you have some security software like "Comodo" installed? Because maybe you have been subjected to malware of some kind?
    If everything else fails, reset to factory settings. But maybe some other people have better ideas here.
    08-04-2014 07:19 AM
  3. Gekko's Avatar
    1. Settings--->Display--->Sleep--->After 2 Minutes of Inactivity
    2. Switch to a different Music Player
    good luck.
    08-04-2014 07:19 AM
  4. Bilal ArQob's Avatar
    Thanks guys, it's okey now.
    08-05-2014 05:40 PM
  1. Replies: 9
    Last Post: 12-15-2014, 09:13 AM
  2. I Really Need Help! ASAP
    By Kenn Mondina in forum Ask a Question
    Last Post: 08-12-2014, 09:21 AM
  3. How Future-Proof is Nexus 5?
    By salmanahmad in forum Google Nexus 5
    Last Post: 08-06-2014, 01:48 PM
  4. Replies: 1
    Last Post: 08-04-2014, 09:08 AM
  5. seeking help to dencrypt
    Last Post: 08-04-2014, 07:14 AM
