Results 1 to 5 of 5
    Nigel Huang's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default No sound from earpiece, sound from speaker
    When I make calls and recieve calls, no sound comes from the earpiece at the top, the volume level is maxed out and nothing. Then when I go and press the speaker it works. The phone is only 1 week old... the only thing installed is battery doctor
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,764 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: No sound from earpiece, sound from speaker
    Sounds like a hardware defect. Does the problem persist after a reboot? How about a cache partition wipe? Keep in mind that the latter can take up to 10 minutes, but you won't lose any personal data: [GUIDE] Nexus 5 Recovery
    If the problem continues, I'd contact the place you bought the phone and ask about a replacement.
  3. #3
    Umer Dawood Chishti's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same issue, tried everything possible from downgrading the OS and radio firmware. To trying different ROMs, nothing has helped so far.
  4. #4
    Buddy1969's Avatar
    Posts
    Global Posts
    722 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe the headphone jack is stuck. You can try an insert a headphone, see if that works, then pull it out again and see if the earpiece works again.
    May be worth a try.
  5. #5
    martin bristow's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thankyou Buddy1969, inserting/removing the headphones on my Nexus 5x fixed the dead earpiece problem for me!
  1. Telmo from Portugal
    By Luis Telmo Pereira in forum Introductions
    Last Post: 08-05-2014, 08:45 PM
  2. no message
    Last Post: 08-05-2014, 03:00 AM
  3. Sound Profile Reverts to Silent
    By ejan33 in forum Verizon HTC Rezound
    Last Post: 08-04-2014, 10:43 AM
  4. Galaxy S5 shows no SD card
    Last Post: 08-04-2014, 10:23 AM
