1. andport3's Avatar
    Put on charge (turned off) about 1:30am at around 14% and when taken off at about 10:30am or so at 76%. That more or less happened the night before too. All this last week the battery really has been appealing.
    I reset cache, not improved.
    I uninstalled most out of the few third party apps I had. (Only had 3 pages on my phone, now two)
    The only apps I even use are chrome, Skype, and since a few days after this problem started Gsam battery monitor.
    08-06-2014 06:55 PM
  2. B. Diddy's Avatar
    Are you using the original cable/charger? Is it plugged into a wall outlet or a computer USB port?
    08-06-2014 07:35 PM
  3. andport3's Avatar
    Yes the original. Plugged into the wall.
    My charger may be damaged because it's short and I often use it while plugged in, bending the cable and sometimes yanking on it accidentally.
    But the ridiculous power usage from 100% which has no relation to the charging makes me thing the phones battery is damaged.
    I plugged it in this morning 10:30am, used it a little in between and took it off charge at 3pm 90%.
    08-07-2014 10:41 AM
  4. Bront's Avatar
    I posted in your other battery thread. Lots of screen power usage.
    Also, how often do you have data updating (Email, apps, etc)? Do you have "Ok Google" turned on or off? Try setting the updates to longer intervals and turning off "OK Google".
    08-07-2014 12:57 PM
  1. Replies: 3
    Last Post: 08-09-2014, 07:21 PM
  2. Nexus 5 Charger gets hot when charging
    By digitLIX in forum Google Nexus 5
    Last Post: 08-06-2014, 11:33 PM
  3. Replies: 1
    Last Post: 08-06-2014, 07:48 PM
  4. Nexus 5 Charger gets hot when charging
    Last Post: 08-06-2014, 06:36 PM
  5. Does the S5 come with BOTH GSM and CDMA?
    Last Post: 08-06-2014, 04:07 PM
