Who knows they finally talked me into doing a factory reset and I will see if it makes any differences.
The 10 most annoying Android 5.0 Lollipop problems solved
You mean switching from volume button or the power menu correct?because you can turn it on with 2 buttons first minus on volume and second select none on the menu for x hours
You can fix the setup with what priorities you want so that notifications alarm are not silencedThat is not the same thing. That will also silence LED notifications/reminders and also alarm. The previous Silence just silenced vibrations and sounds.
