As you can see, in just a few hours, the battery is down to 80% and draining at an unusual rate. I was originally on Lollipop 5.1.1, and the battery life was fine, I used to get around 22 hours with one full charge. Then I flashed M preview 2, and I had the random WiFi Mac address issue, so I flashed M preview 3. The WiFi Mac address issue was resolved, but this new battery drainage issue popped up. I used it for 2 days on M preview 3 and couldn't take the headache, so I flashed Lollipop 5.1.1 again, and yes I've done everything cache wipe, factory reset and etc, still the issue remains. I'm a stock freak and I keep my phone well optimized for better battery life (lowest brightness, sync set to maximum and etc). I don't use any task killers or battery apps either. However, I've noticed, once the battery comes down to about 40%, it drains at a normal rate and all the apps that I'm using are shown in the battery info screen. Before this happens, very few apps appear on the battery info screen as you can see in the image. Restarts don't help at all. I'm tired of flashing and factory resetting... Safe mode doesn't make any difference either. What do you guys suggest I do?
