BLuetooth Problem with Nexus 5 android 6
Oct 11, 2015
6
HI all,
Anybody having the the problem in subject after the upgrade?
The problem occurs when I try to call but it works if receive a call.
Any helps?
Regards\Vincenzo
I'm not sure what your problem is. I use Bluetooth earphones to listen to music when I walk my dog and they are working fine with Nexus 5 and Android 6.
I use in my car, first I done the upgrade it was working perfectly, now it can receive call but if I call the people cant hear me!
I have a similar problem when I try to dial the car multimedia system,
The phone starts to dial but the same is disconnected from the device as incoming calls.
Before upgrading to Android 6 was all right.
I did a factory restore both your phone and car multimedia system.
** This is a multimedia system of Mazda in 2015
I am facing the same problem. I did a factory reset, but that did'nt fix the problem.
factory reset => still Android 6
My car: Opel Insignia Sports Tourer
Hi All,
After the factory reset, it works better but not completely, actually, when the mobile is connected to bluetooth car, the receiveing work, instead the calling work only if I send the from the mobile then I send the from touchscreen of the car it doeasnt work.
At this point I think is clear there is some problem with bluetooth after upgrade, I dont know Who can I inform for this think, also because it's impossibile to have the downgrade,
Anybody with my problem know who we can call or inform for this issue?
BR\Vincenzo
PS
My car is peugeot 208
I'm having the same problem, the Factory Data Reset didn't solve it.
What happens is that when in the car, listening to radio/music from USB stick and want to make a call, I go into Telephone menu (from MediaNav, the car's multimedia system), search in the phone's addressbook or just select an entry from recent calls list, the music is not paused (as it should and as it used to happen when using the same Nexus 5 but with Android 5.0), the phone call is made but the audio link is not started... the other person is not hearing anything while I keep hearing the music from my radio/USB.
I have to close the call and try again, for 4-5 times if I'm lucky enough :)
I have a 2015 Mazda3 SP25 and mine is doing the same thing. it initially rings then cuts out. the funny thing is, the actual phone is still ringing.
I have tried app permissions, changing default apps, removing pairing and cant get it to work. messaging through car works, but contact names wont appear.
At least I know im not the only one!!:(
Hi, I have the same problem in my car. On Android 5 all work fine but now it s complicated to call. My car is a Peugeot 308
Have similar issue. The Bluetooth on my Nexus 6 disconnects in 30 seconds after initial connection with BMW X6 2013 car audio system after update to Android 6
Also to know if there will be some upgrade of android 6...
Who can we inform?
Another thread covering this: Titled "Bluetooth regression in Marshmallow with Nexus 5" at productforums.google.com. (sorry, cannot post link because I'm only at my 2nd post here)
Seems Google people read that thread?
Hello Vincenzo,
I have the same problem with my CITROEN C4 (2012).
i have no problem before in Android 5.1.1 with my NEXUS 5.
I don't use my N5 with the car much, but after the Android 6.0 update, I am having increased problems with trying to connect to my Motorola headset. Sometimes I have to try to connect several times before it finally connects. Never had this issue before. Yet, it (N5) seems to connect to my home wireless phone OK. Also had problems with trying to get it connected to my 360.2, which was odd.
Connection to my 2014 Honda Civic is also sporadic. Before, when I turned the radio on (in aux mode) it would automatically launch Google Play Music. Now it launches sometimes, sometimes it will show "no track" and other times nothing.
SInce android M with my nexus 5 I have a problem with phone in my car ( peugeot 508) . I can answer to a call, but, I cn't call from the system
I can call out, but I do not hear the number dialing and it seems like nothing happened.
When I look at my Bluetooth pairing settings, I briefly see this:
Then, I quickly see this:
slackingfred
