Isn't there and LCD notification light behind the top speaker? I don't see LED in Settings.
Moto phones only have the LED for the purpose of indicating the phone is charging when the battery is too depleted to power the screen.
You'll have to chill for a bit the app developer for light flow is working on this
Huh? Most apps already have LED support.
Nexus six uses ambient display. Move or pick up the phone and you will see your notifications.
Right but the Dev for light flow needs to update his app so that it's compatible with nexus 6
Light flow is an app for previous nexus devices where you could assign specific led colors to notification light. There is buzz on XDA about a led light behind the top speaker and creator of the app is looking to see if the 6 could benefit. For me I'd prefer the notification light to ambient display. I don't run security on lock screen and have found my phone doing things on its own while in my jean pockets.
What about a just native LED support in the OS?
That's how it works...yeah, I turned off ambient display because the display keeps turning on while it's just sitting on the table without new message coming in.
The nexus 6 doesn't have a native led they replaced it with ambient display ....they are trying to hack one into use
http://www.droid-life.com/2014/11/21/nexus-6-has-a-hidden-rgb-led-under-the-top-speaker-grill/
LED activation and settings info.
