How to force alarm sound to go to the speakers when headphone is plugged.
odror
Active member
Dec 21, 2010
37
Hi
I switch from GS4 to the N6. One thing that I am missing is the abillity to have the alarm clock sound go to the speakers, when the headphones are plugged in.
Any way to fix that,
Thanks
Hi
Thanks
I have a similar issue, but regarding notifications, mostly calls. If I'm listening to music on headphones or aux jack in my car and a call comes through, the ringtone sounds on the external speakers, not through the jack or headphones. I can't find anything in the settings to change it
I found a semi solution by installing the app Headset Ringtone Manager Lite. The app adds a ringtone through the headphones while they are plugged in, but the phone still vibrates unfortunately
I surprised this isn't a more common issue/complaint. With my Note 3, it silenced vibrate/ringtones and sent a notification through the headset or jack without any tweaking and adjustment.
No one else minds their ringtone blasting through their external phone speakers while they are wearing headphones?
I am trying to find a way to force the alarm to play through the speakers when my phone is connected to a bluetooth earpiece. Sometimes I forget to disconnect it at night which can cause me to oversleep in the morning due to not hearing the alarm ringing through my bluetooth earpiece. There must be a way to do this!
Not sure... But did you look into automation apps like Tasker?
Maybe you can write a rule for doing this.
9
please tell me u have the answer now...
The problem seemed to only be with custom Lollipop ROMs. Once I upgraded to MM ROMs, the alarm sounds through BOTH my bluetooth earpiece and the phone's speakers which is perfect for me!
slackingfred
