1. jcg09's Avatar
    The first time my Nexus 6 rings, the volume is is very, very low. During the second ring, the volume starts to increase and is at the set level by the time the second ring comes in.
    Does anyone have a fix for this?
    Thanks,
    Joe
    12-27-2014 11:57 AM
  2. GilmourD's Avatar
    Thanks,
    Joe
    Seems to be a Lollipop issue as my Moto X 2014 does the same thing since the update.
    12-27-2014 12:06 PM
  3. wtherrell's Avatar
    Yup. Just the way God........ er, I mean Google intended.
    V6Hawk likes this.
    12-27-2014 01:30 PM
  4. integr8d's Avatar
    I've noticed the same thing. I wondered if it was Google's way of letting you catch a call before the ringing got too loud. If not, plenty of other things I'd fix first. But I'm definitely in your boat as well.
    12-28-2014 04:54 AM
  5. whynotpolonium's Avatar
    I haven't noticed that yet, only had a nexus 6 for a few days, but my HTC One X had this as an option and I liked it. Shame if it isn't selectable.
    Maybe if people complain about it Google will change it, I've seen a few people complain about not being able to change the chat bubble colour on the message app and that got fixed.
    12-28-2014 06:41 AM
  6. N4Newbie's Avatar
    Exactly!
    I don't see this as an issue at all. As mentioned above, it gives me a chance to answer a call before the ringing becomes obnoxious - I normally keep the ring volume quite high because I am in different environments throughout the day and cannot always easily hear it.
    12-28-2014 07:40 AM
  7. Kwdan's Avatar
    On my phone I can control that.. Settings/sounds/"increase ring volume" www.dropbox.com/s/1ghun42wptu8dya/Screenshot_2014-12-28-08-45-34.png?dl=0
    12-28-2014 07:46 AM
  8. ODog2323's Avatar
    I've had this "feature" on a few phones now, and have come to appreciate the more subtle alert before the ringtone blasts me.
    AC App
    Nexus 6
    12-28-2014 07:57 AM
  9. DroidGuy3's Avatar
    lol !! by the way, this volume thing is so annoying .... & why the poor choices when it comes to alarm sound options on the N6??? why did google decided to make the most relaxing alarm sounds in the history of alarms??? we need rude & annoying alarms ha !!!
    GilmourD likes this.
    12-28-2014 03:30 PM
  10. DroidGuy3's Avatar
    but the same applies when you call someone, especially on speaker, there is a delay in volume increases, so as soon as the person answer, you can't hear them until volume adjusts, this is not a good thing!
    Stevieboi likes this.
    12-28-2014 03:39 PM
  11. danielcj's Avatar
    I think it's a bug as I notice it on my Moto X. Plus if you have sms sounds that are short sometimes you miss a message because the sound was too low. If it did it on ring tones I could maybe see it as a feature but the fact that it is happening to notification sounds tells me it's a bug.
    12-28-2014 10:42 PM
  12. whynotpolonium's Avatar
    That sounds more like a bug than a feature for sure
    12-29-2014 06:09 AM
  13. Kwdan's Avatar
    https://www.dropbox.com/s/1ghun42wpt...45-34.png?dl=0
    Is it a bug or feature? I'm running "Liquid Smooth Rom" and it's a feature with adjustments.
    12-29-2014 02:12 PM
  14. Lee_Bo's Avatar
    Alarm sounds to the same thing.
    12-29-2014 02:55 PM
  15. tr-1's Avatar
    I love this feature. It allows me to pick up the phone or silence it before the entire office hears it.
    12-31-2014 04:22 PM
  16. skuni's Avatar
    Any news on how to adjust this? I don't mind it on ringing but I miss stuff when switching to speaker phone during a call.
    01-02-2015 09:34 AM
  17. radicchio's Avatar
    Too bad they didn't apply this to the AT&T opening boot up sound. It's my understanding that it's quite loud. Definitely should have made that start up softly so it's not so intrusive, especially if having problems with random reboots and it's rebooting during a business meeting, at the theater, etc.
    01-02-2015 11:21 AM
  18. S GTG's Avatar
    IF ALL ELSE FAILS
    Hi guys I'm new to the forum but i hope i can help as my Moto g 2nd Gen had the same problem and it's running ok for now......
    You are going to need to plug your phone into a computer and on AUTO PLAY click "OPEN FOLDER TO VIEW FILES".
    1) Go to Media folder > Audio > Ringtones
    2) Copy all ringtones and go back 3 tabs to the main storage page of your phone
    3) Open Ringtones folder and paste your ringtones
    4) Close the window, unplug your phone and cross your fingers it has solved your problem.
    Worked for me so i hope this helps others.
    Good luck
    03-29-2015 03:22 PM
  19. BargainingJew's Avatar
    This is a stupid "feature" that Google added to Lollipop. It is not user selectable. It is especially annoying on speakerphone calls. Absolute idiocy.
    03-30-2015 05:45 AM
  20. wtherrell's Avatar
    IF ALL ELSE FAILS
    Good luck
    Nope, that didn't work on my Nexus 6.
    03-30-2015 06:38 AM
  21. George Bekris's Avatar
    Hi everybody!Purchased the google nexus 6 32GB (white) last Friday and got it yesterday and have been using it for almost 24 hours! I have noticed this delay and its about 2 seconds. The sound delay is everywhere. If you press play on a youtube video there will be a 2 second delay until the sound of the video reaches the speakers. Same thing goes when somebody is calling you or messaging. The volume will start low at the top speaker and after 2 seconds will work properly. Also while having a phone call if you press the speaker button, it will take 2 seconds until the speakers are activated. I don't know if its a bug for the 5.1.1 or if its some phones but i personally called Google today and reported the problem. Would like to know if there is a fix or if its a device problem.
    07-16-2015 08:21 AM
  22. Andrea B3's Avatar
    NEXUS 6 ASCENDING/INCREASING RING: FIXED. Yeeeeeeeeah!!!
    I *had* the same problem since the first day of use of my N6 until... yesterday! The upgrade from Lollipop to Marshmallow didn't fix it, as I hoped. The only things I did yesterday are the following:
    1. I uninstalled Google Launcher directly from the Google Play Store
    2. I uninstalled Google directly from the Google Play Store
    TIP: Search "Google Now" on the Play Store. Two results appear in the following screen. Tap the first result and uninstall it. Go back, tap the second one and uninstall it as well.
    Then I reinstalled both. After that, I had to rebuild my home screen manually, my folders and so on. A lil disappointing, but it took just 10 minutes (and a couple of blasphemies... helpful, as usual). You can take a screenshot of your home screen (powerbutton+volumedown), first. This will help you rebuild everything.
    3. I changed the ring from "default" to... the same ring but with its name, choosing it from the stock helper app "Media Storage". I did the same with Google Messenger and Whatsapp.
    4. I installed the official LinkedIn app.
    Magically, the increasing ring has disappeared. The funny thing is that I was trying to fix a different problem! :-)
    I imagine that both LinkedIn and Whatsapp doesn't matter...! I'm just telling you *all* the things I did.
    Let me know if it works, please. If it does, I'll disseminate this information all over the web, since a lot of people have this problem which, as I've understood, must be a software bug and not a hardware lock or a hardware bug as I red in certain forums.
    Byebye,
    Andrea - Milan, Italy
    11-09-2015 08:02 PM
  23. brodazunino's Avatar
    Thanks,
    Joe
    Thanks
    04-15-2017 09:43 AM
  1. does the battery break-in?
    By mpgo4th in forum Motorola Droid Turbo
    Last Post: 10-24-2016, 10:56 PM
  2. How to get pics off my Nexus 5?
    By dafinvic2014 in forum Ask a Question
    Last Post: 01-25-2016, 09:23 AM
  3. [FREE] Granny vs. Zombies! My very FIRST game release.
    By Playzoid in forum Android Games
    Last Post: 01-05-2015, 05:02 AM
  4. Replies: 2
    Last Post: 12-28-2014, 03:05 AM
  5. Replies: 0
    Last Post: 12-27-2014, 10:13 AM
