1. jstar8000's Avatar
    So i was changing the fonts in the Rom Toolbox, and when i powered off and then back on, it wouldnt go past the nexus X start screen. Any Help?
    08-03-2012 10:50 AM
  2. digitalslacker's Avatar
    that's not bricked
    bricked means it won't boot
    do you have a backup? just restore to that if you can.
    08-03-2012 11:15 AM
  3. 2defmouze's Avatar
    As digitalslacker said... worst case is you have a softbrick -- easily fixable, don't panic!! Hopefully you made a backup and can just boot into recovery and restore that?
    If not, might have to check my guide for restoring the factory images... its not hard at all and will get you right back to stock condition. For the future, always make a backup before tinkering with stuff
    Let me know if you need help!
    08-03-2012 11:45 AM
  4. stick2e's Avatar
    If you didn't make a backup here is the link to restore back to factory
    http://forums.androidcentral.com/nex...nexus-7-a.html
    That's always a way out
    dmmarck likes this.
    08-04-2012 06:59 AM
  5. Drakath Wong's Avatar
    Is there a way to back it up while soft bricked?
    12-26-2012 05:12 PM
  6. digitalslacker's Avatar
    ADB backup/restore might work for that if you have adb access
    never tried it though
    12-26-2012 06:06 PM
  7. Drakath Wong's Avatar
    If its soft bricked doesnt it mean no abd access?
    Also if I do a factory reset will my backed up data on clockworkmod be removed?
    12-26-2012 06:21 PM
  8. digitalslacker's Avatar
    Soft bricked has come to mean a number of things. People use the term so loosely now that it can even mean a boot loop.
    Easy enough to check, get into the bootloader and try adb devices and see if it's listed.
    As far as I remember using the images will completely wipe everything on the device. Just like it came outa the box.
    12-26-2012 06:49 PM
  9. Drakath Wong's Avatar
    My Nexus 7 is also stuck at the X because I installed Elite Kernel. Can anyone please help?
    Also I do not want to loose my data or at least back up it on my laptop
    12-26-2012 07:30 PM
  10. digitalslacker's Avatar
    If you can find the stock kernel you can probably just flash it with adb.
    12-26-2012 08:16 PM
  11. Drakath Wong's Avatar
    I got the stock kernel but not sure how to flash it.
    Thank you.
    12-26-2012 08:32 PM
  12. digitalslacker's Avatar
    Thank you.
    So there are three ways to fix it.
    If you can get into recovery CWM or TWRP and you can find a flashable zip of the recovery you can just flash it and you'll be good. I think it's located here but I haven't tried it so i don't want to say for certain. http://forum.xda-developers.com/show....php?t=1929459
    Or, If you are also running a custom ROM with your custom kernel that isn't working you can just reflash the ROM zip file in CWM or TWRP as it will have it's own kernel that it'll flash over the broken one.
    Lastly, if you have the stock kernel in image format (.img) you can flash it with ADB from your computer. You'll need ADB access setup, you'll need to put the phone in bootloader mode and use the command fastboot flash boot <image name>.img
    There are plenty of guides around on this one.
    If you give me more info on how you are setup I could suggest an option.
    Sent from my Transformer Prime TF201 using Tapatalk HD
    2defmouze likes this.
    12-27-2012 07:21 AM
