Nexus 7 Bricked !!Bootloader Erased Help!!!!
Vgarcia24
5
My brother erased de bootloader with "fastboot erase bootloader"...
How can re-install de bootloader on my nexus 7?
Hey caldera thanks for the help... But i dont have bootloader. so i cant do anything of that .
If you can't get into recovery or flash anything through fastboot then you're probably out of luck. I'm not sure what Asus charges for this type of "repair", but it probably isn't cheap. My condolences for your loss. :(
well... thanks...
a thinks there is a way. im waiting for nvflash people... they did the same with a asus transformer...
I don't think anyone has used NVFlash with the N7 yet, but that doesn't mean it won't happen eventually. Best of luck.
Wait.. so what happens when you power off and try to boot into the bootloader with volume down + power?
thats true... but i will keep this one. and wait for the nvflash for nexus 7.... if you news about that, please let me know..
thanks
Wow you'd think there'd be some kind of protection against that anyways there's gotta be some way to get it back they had to flash a bootloader at the factory so that means there is a way to flash it the question is how did they do it at the factory
Sent from my Nexus 7 with CM-10 using Android Central Forums
All the images are here https://developers.google.com/android/nexus/images make sure you download the right one. the WiFi only Nexus 7 is Nakasi also you will want to know which version you had on there 4.11 4.12 or 4.2 so you can put the right bootloader back.
i think it is actually grouper nvm they chaged the name
my friend bricked his transformer and it cost like $250 bucks to fix. they replaces parts in it instead of reprogramming it.
i also googled nvflash and it seems it only works if you have already backed up your files
Grouper is one codename... Nexus devices have a second codename that applies to their factory images. For example: Nexus 7 (Grouper) is nakasi (wifi only one) and nakasig (3g enabled one) ; Galaxy Nexus has a few varieties (toro = Verizon, toroplus is sprint, maguro is the gsm version) with respective image-names (mysid, takju and yakju) ; Nexus 4 (mako) is occam... :)
Seems that some people have been playing with nvflash and have gotten it to recognize but haven't figured out a way of flashing anything yet at any rate there should be a way to do it soon also 2defmouze nvflash stands for Nvida flash
Sent from my Nexus 7 with CM10 using Android Central Forums
With the command 'fastboot erase bootloader' check the first post
Not necessary if this is rooted. Do you have custom recovery? If so, you can find the bootloader in zip format, copy it to your N7, then flash the zip from CWM or TWRP. Other wise, you made need to do a factory wipe and start from scratch. There is a way to do it from powered off state, I'll look around.
lefler
