1. rshane01's Avatar
    I'll spare you the details of how I got to where I'm at. Bottom Line is I lost root when going to 4.2 and can not for the life of me get rooted again. I'm trying to flash CM10
    Anyways, these are the things I've done to try to get rerooted
    1) Hard reset - doesn't work
    2)manually wipe from PC (done this multiple times with evo)
    3)Tried rooting with 2 different tool kits
    4) Bunch of other crap for 8+ hours
    Another issue is when I try to boot into recovery, it won't go into recovery mode. Any option I choose reboots my tab to lock screen. Ive deleted all drivers from PC and any and all apps that are root required ie Busybox and CWM Rom Manager
    I either want to start from scratch or throw the dang thing at a wall. I love the Nexus7 but today, I've freakin had it! All issues are fully my fault and I'm hoping for mercy from the Android Gods!
    I apologize if things dont make complete since as I'm seeing double and my brain is fried.
    Thanks
    11-26-2012 06:15 PM
  2. dark_samus's Avatar
    Reinstall the ROM manager and use it to boot into recovery and install cm10 or just reflash the superSU package
    Sent from my Nexus 7 with CM-10 using Android Central Forums
    zero neck likes this.
    11-26-2012 07:03 PM
  3. 2defmouze's Avatar
    Follow the instructions in Zero's guide, using the files I linked to in the very last post, direct link here: http://forums.androidcentral.com/nex...ml#post2356879
    11-26-2012 07:10 PM
  4. zero neck's Avatar
    i updated that thread its good to go for 4.2
    2defmouze and Jaysus like this.
    11-26-2012 10:51 PM
  5. rshane01's Avatar
    Thanks for the quick response!!!
    Can you recommend a program to open the .img? I've tried Deamon but it doesn't support, I downloaded magicISO which does support but it fails to mount the image on both my PCs. WinZip doesn't do me any good either and I don't have Nero, the free version is useless.
    11-28-2012 01:20 PM
  6. 2defmouze's Avatar
    You don't need to open the img file, you write it to your device via fastboot.
    11-28-2012 03:26 PM
  1. Nexus 7 Not Connecting to WiFi after 4.2 update, PLEASE HELP!!!
    By Soham Kale in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-17-2014, 09:14 AM
  2. HTC Design Wifi Issue -- Please Help.
    By Sahveen in forum General Help and How To
    Last Post: 11-07-2012, 10:28 AM
  3. rooting issues. please help
    By smoking rr in forum G2X Rooting, ROMs, and Hacks
    Last Post: 05-27-2012, 05:27 PM
  4. WIFI Issues PLEASE HELP
    By jegordon23#AC in forum AT&T Captivate
    Last Post: 12-22-2010, 07:32 AM
  5. Wifi issue, please help?
    By shypnoi in forum General Help and How To
    Last Post: 12-20-2010, 08:05 AM
