Results 1 to 8 of 8
    mdewey1138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default USB OTG problem
    I have a rooted nexus 7. I installed stickmount but am still unable to see my usb stick.
    Please advise.
    Mike
  2. #2
    digitalslacker's Avatar
    Posts
    Global Posts
    1,641 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: USB OTG problem
    Quote Originally Posted by mdewey1138 View Post
    Please advise.
    Mike
    Is stick mount listed as a root app when you open up the SuperUser or SuperSU app?
    If not then you missed the prompt that first popped up when you ran stickmount where it requested root access.
    If you don't have the superuser app then you may not have rooted
    How are you trying to access the usb device? It's only browseable via a file manager, it's not available to other apps as i understand it. Meaning if you throw your music there I don't believe the music app will know to look on the USB device for your files to index. I could be wrong about that.
    mdewey1138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I checked my SU app. Stickmount isnt listed. I uninstalled it, but didnt get the pop up requesting root access. Now what?
  4. #4
    Posts
    Global Posts
    1,641 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    are you sure you are rooted?
    do other root apps work?
    mdewey1138's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As far as I can tell I'm rooted. other apps request root access when starting
  6. #6
    Posts
    Global Posts
    1,641 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    when you use a filemanager can you browse to /sdcard/usbStorage/xxxx/
    I believe that is where the usb stick gets mounted to
  7. #7
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Please advise.
    Mike
    Are you sure the otg cable is working. I have read that some day otg but do not work.
    From my Galaxy Note 2 via Tapatalk
  8. #8
    Groid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try plugging a usb mouse or wireless mouse receiver and see if the mouse works. If not, you may have a non-compatible OTG-usb cable. Some just don't work.
  1. USB OTG problem with cruzer 16GB
    By dmlarsen30 in forum Google Nexus 7 (2012) Accessories
    Last Post: 09-07-2012, 01:45 PM
  2. USB OTG problems / questions
    By hjmillre in forum AT&T Galaxy S3
    Last Post: 08-21-2012, 01:38 PM
  3. Nexus One Gingerbread USB Mode Problem(s)
    By slickyrickyross in forum Google / HTC Nexus One
    Last Post: 03-12-2011, 06:33 PM
  4. USB connect problem
    By revobreaker in forum Verizon Fascinate
    Last Post: 11-05-2010, 12:06 PM
  5. USB Connection Problems - Help!!!
    By DanKatz in forum Motorola Droid X
    Last Post: 10-24-2010, 11:52 AM
