Results 1 to 3 of 3
    Question any problems with cables connecting nexus 7 to the tv?
    i was thinking about buying chromecast, then i found out that it won't show everything on the tablet.
    so i am thinking about buying the cable to connect it to the tv, i wonder if this product has any problems of its own?
  2. #2
    Default Re: any problems with cables connecting nexus 7 to the tv?
    Quote Originally Posted by preppystud View Post
    Look for slimport on amazon or eBay, 1080p 60fps should be about $15. That's what I use
  3. #3
    xchange's Avatar
    Posts
    Global Posts
    357 Global Posts
    Yep, Slimport is what you need. Unfortunately Google chose to use the free license Slimport standard for Nexus while MHL has a much wider adoption and availability. Since my phone uses the wider MHL and since I didn't want to have to use 2 adapters I chose use my phone for TV playback. Just another option you can consider depending on what your phone is.
    The complacency about security among android users is disturbing.
  1. is the Nec terrain a good phone att
    By beckytigeress in forum General Help and How To
    Last Post: 12-29-2013, 10:22 PM
  2. What happen to the side menu?
    By rickap7 in forum Verizon Galaxy S3
    Last Post: 12-29-2013, 08:33 PM
  3. battery drain with netflix?
    By denarok in forum LG G2
    Last Post: 12-29-2013, 08:25 PM
  4. Where to buy Poetic Slimline Case for Nexus 7
    By CIMBOMBOY in forum Google Nexus 7 (2012) Accessories
    Last Post: 12-29-2013, 07:18 PM
  5. Droid phone with no service--can we use it as an iPod?
    By remobec in forum Android 2.3 Gingerbread
    Last Post: 12-29-2013, 06:26 PM
B
