Results 1 to 7 of 7
    lanching123's Avatar
    Posts
    Global Posts
    108 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 7: wireless charging with a case
    I currently have a poetic slim line case on my 2013 nexus 7. after ordering a nexus 5 and an official nexus wireless charger along with it (the small square one, not the orb), i noticed my nexus 7 would not charge wirelessly with the case on it. is anyone using this combination having this issue? I would like to keep the wireless charger but am willing to get a different nexus 7 case that is similar to the poetic slimline if it means i can wirelessly charge. does anyone have any tried and true suggestions for such a case? thanks for your time and help!
  2. #2
    Gwaron's Avatar
    Posts
    Global Posts
    327 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: wireless charging with a case
    The nexus wireless charger is very sensitive to how the phone is placed. Make sure you move it around a bit to find the sweet spot
    Posts
    Global Posts
    108 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did attempt to move it around carefully on a few occasions. I will certainly try it again but I tried to be very thorough on my first few attempts without any luck. I have a feeling it is not possible with this case but I could be mistaken.
    Posts
    Global Posts
    108 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 7: wireless charging with a case
    OK after painstaking trial, I don't think this thing is going to wirelessly charge with this case on this charger. Now I am on the hunt for a similar case that will for sure work with this charger. Any suggestions?
  5. #5
    pete1118's Avatar
    Posts
    Global Posts
    268 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use the Poetic with a Nokia dt910 and it works fine although it is slightly touchy about placement.
    Sent from my Nexus 7 using Tapatalk
  6. #6
    jerrykur's Avatar
    Posts
    Global Posts
    1,232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have also used the poetic case with the Nokia. Both the 900 and 910 work fine.
  7. #7
    DolphinDroid's Avatar
    Posts
    Global Posts
    477 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use the Nokia wireless charger with my Nexus 7 protected by a Moko Slim Fit Case.
  1. Replies: 5
    Last Post: 01-13-2014, 06:20 PM
  2. Poor LTE signal with moto x on Verizon
    By erjennin in forum Moto X (2013)
    Last Post: 01-13-2014, 02:54 PM
  3. Can HTC ONE be used with no problem in a lite rain ?
    By Alvaro Miranda1 in forum HTC One M7
    Last Post: 01-13-2014, 11:09 AM
  4. Replies: 2
    Last Post: 01-12-2014, 10:01 PM
