1. Jr Lagos's Avatar
    I was trying to press the "wipe cache partition" but I accidentally press the " apply upgrade ADB". So please help me on how to repair my 2013 nexus 7
    02-12-2014 11:35 PM
  2. AndroidProf's Avatar
    You have to be clearer for us to be able to help you mate. If you're stuck in a bootloop, you can simply boot into the recovery of your device and do a factory reset and also do a wipe of cache partition. If you somehow have screwed up your OS, you can flash in the factory images by searching for them online (Hint: It will be a Google page)
    You will require Android SDK installed on your computer. Just click flash-all.bat if you're using windows to get started after downloading and extracting the downloaded file.
    02-13-2014 04:27 AM
  1. Wifi problems with dual band router
    By recDNA in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-15-2014, 10:03 AM
  2. Problem with Google Drive App on Asus Memo Pad 7
    By wigwam3 in forum ASUS MeMO Pad HD7
    Last Post: 02-14-2014, 07:20 PM
  3. Hello i have simple problem...
    By RAvEcREAToR23 in forum Samsung Galaxy S3
    Last Post: 02-13-2014, 04:29 AM
  4. Replies: 8
    Last Post: 02-12-2014, 10:58 PM
  5. Problem using micro usb cable with nexus 10
    By Mr Tickle in forum Google Nexus 10 Tablet
    Last Post: 02-12-2014, 11:20 AM
