Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By wizzrah
    j0hnnyyyy's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need help
    So i decided to root my nexus 7. I have a mac so i followed ray ban fedora video guide on youtube followed all instructions and everything went alright. when i went to download titanium backup it says that I'm not rooted and to check my rom. i have supersu installed when i went to the app it says that SU binary needs to be updated. need help am i rooted or did i mess up?
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Default Re: Need help
    Quote Originally Posted by j0hnnyyyy View Post
    You should update the binaries. Usually that means that you did not flash the most up to date version of SuperSU.
    j0hnnyyyy's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wizzrah View Post
    i downloaded it off of supers website. CWM-SuperSU-v0.98.zip is this the latest?
    j0hnnyyyy's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    sorry I'm new to this and very worried about bricking my nexus so how would i update the binaries?
  5. #5
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    The latest version is here: http://forum.xda-developers.com/show....php?t=1538053
    You would flash it in recovery. The link says "CWM / TWRP / MobileODIN installable ZIP" so it is compatible with most recoveries.
    You Download the zip and put it on your nexus. Then boot into recovery. Flash the zip. Reboot the tablet. I believe you can make a backup in recovery as well if you are worried.
    Sent from my One Xl using Tapatalk
    j0hnnyyyy likes this.
    j0hnnyyyy's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The latest version is here: [2014.01.20] SuperSU v1.91 - xda-developers
    so go into recovery and go to install and flash the new twrp? i already downloaded the link you posted
  7. #7
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    TWRP? You mean the latest version of Supersu? Yes. Download it, put it on your nexus, then flash in recovery.
  8. Thread Author  Thread Author    #8
    j0hnnyyyy's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks wizzrah you help me with the problem now just have to do some research on how to put the elementals kernel so i can use an otg and power usb device and charge nexus 7. do you have any other links that can steer me in the right direction on the kernel and I'm guessing i need a custom rom as well?
  9. #9
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Usually you flash a ROM before a kernel, but in this case, it seems you don't. The elementalx kernel has the OTG USB charge enabled. My nexus 7 2013 is stock and untampered :P so I only know so much.
    Check out the xda forum for stuff like that.
    http://forum.xda-developers.com/nexu...13/development
    Best thing to do is read! Best of luck!
    Edit: Sorry, linked it to the nexus 7 2012 version. Updated it so it links to the 2013 forum.
  1. Help with Samsung Galaxy S3-Keeps turning off
    By Alexis Momney in forum T-Mobile Galaxy S3
    Last Post: 11-14-2014, 07:54 AM
  2. Nexus 5. Help finding files using windows 8
    By Nicholas Forsythe in forum Android 4.4 KitKat
    Last Post: 02-01-2014, 09:13 PM
  3. Nexus 5. Help finding files using windows 8
    By Nicholas Forsythe in forum Google Nexus 5
    Last Post: 01-30-2014, 12:25 AM
  4. I need HELP!!
    By puffiestpanda in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-29-2014, 08:28 PM
  5. need for speed mW on nexus 7
    By Del Wright in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-29-2014, 07:05 PM
