Results 1 to 9 of 9
    Default Anyone else having this problem with their nexus 7?
    2 screen issues on Nexus 7 (glass separation/dead pixels) | The Verge Forums
    i don't wanna receive my nexus and have this problem...
    my Toshiba thrive also had the glass problem and it bothered the hell outta me.
  2. #2
    cohoman's Avatar
    Posts
    Global Posts
    912 Global Posts
    Carrier
    HTC One Stock All the Way
    Default
    The link you posted says the glass is lifted by 1 mm, which is a lot. I have to report I don't see any of that... the glass on my N7 is flush all around and I can't detect any sponginess.
  3. #3
    tntdroid's Avatar
    Droiderator
    Posts
    Carrier
    Bugless Nexus
    Default
    See this thread started already about this.
    Nexus 7 Glass Seperation
  4. #4
    Default
    Might not be relevant but I had the spongy lifted glass on my iPad 2. When I'd push down then lift off you could hear the glass popping off the glue. They replaced it immediately. It's definitely a defect.
    Sent from my HTC One X using Android Central Forums
    Default Re: Anyone else having this problem with their nexus 7?
    Quote Originally Posted by tntdroid View Post
    this sucks some people are saying you can just hold it down for 10 minutes and it'll say, i hope mine doesnt come like this.
  6. #6
    eze036's Avatar
    Posts
    Carrier
    ICS
    mine having same issue.. i held it for 30min while i was playing dead trigger it seems fine now.. hopefully it doesnt pop back up...not a huge issue but if it does happen again ill probly go get it replaced
  7. #7
    Angry Re: Anyone else having this problem with their nexus 7?
    The first Nexus 7 I received had a bad speaker, I just got my replacement Nexus 7 and it has the screen separating issue right out of the box. So now I have to send that back so they can try and send me a 3rd unit. Not good, not good at all very unhappy
  8. #8
    ldfeat's Avatar
    Posts
    Global Posts
    17 Global Posts
    Just got mine yesterday (7-29-2012) at sams and don't see that problem.
  9. #9
    my screen is red and the copy is red...how do i correct this?
