12-01-2013 01:56 AM
62 123
tools
  1. sojodave's Avatar
    My wifi works great at home, but not at other places. Isn't there an app for this?...:-)
    10-21-2012 02:04 PM
  2. sinlessmd's Avatar
    I had a problem with my nexus, First time I connected through my home wifi everything went well
    I was thrilled! So I turned it of and wend to bed. The next day when I started
    The tablet I saw the wireless 4 bars but the triangle on the upper right corner was gray.. I search on the internet for a solution but no luck!!
    But when I turn on my laptop BOOM FULL INTERNET SIGNAL!! So what happened? Just that my nexus saw my laptop as a hot spot. So I changed my wifi settinings from DHCP to Static. Go to IP Address and change it.. :-)
    11-09-2012 01:37 PM
  3. cognus's Avatar
    11-14-2012 07:54 AM
  4. andre47's Avatar
    I have a Android 4.0.4 device and the same problem with my ASUS 66.
    My solution:
    I just changed my password and changed all signs into numbers. Android seems to have problems with some special characters.
    11-17-2012 04:36 AM
  5. salvefon's Avatar
    Yes. I have problem connecting Nexus 7 to my Clear wifi. What could be the problem and solutions for that? I appreciate your help.
    12-02-2012 04:20 PM
  6. visitor1234's Avatar
    You are my GOD for the day.
    I had the exact same problem with my Nexus 10.
    I set up the IP address statically and I was good to go.
    12-12-2012 03:00 PM
  7. Terry Beaudette's Avatar
    Hey what's up.
    So my suggestion may be the most obvious answer but the same thing just happened to me today after I reset my phone to factory settings. I did not properly input capitol letters in WIFI authentication password where I had them. As soon as I re-entered password with proper capitols, it connected immediately. So check if you missed some capitols.
    I hope this helps.
    Terry
    12-26-2012 01:06 AM
  8. Unforgiven118's Avatar
    I've had problems with my Droid DNA and wireless N. It would connect to my G but not my N. The only way it connects to N is if I turn off my router security.
    12-26-2012 02:03 PM
  9. Unforgiven118's Avatar
    Nvm figured out the problem. On my wpa I had to change the encryption from TKIP to AES. Wireless N works fine on AES now.
    12-26-2012 03:13 PM
  10. stryfetew's Avatar
    I'm having the same problems.. I'll get the connecting, obtaining then nothing.
    02-04-2013 08:30 PM
  11. snrash's Avatar
    Hi
    Ip adress how do we know it?u said for urs it is 192.168.77.Im using wifihotspot from mobile to try connect to nexus 7
    10-25-2013 02:43 AM
  12. Tamzyn Stone's Avatar
    Thank you!! this worked perfectly for me!! (changing to static ip)
    i have spent approx 4 days trying to just set up my secondhand nexus 7. had even sent ebayer a msg about possible refund. finally on a forum found out that my wifi logo should be blue not grey! (im a apple head this is first android device ever owned and only bought for my children for xmas) then found this and wallah!! everything is working perfectly i can finally set this device up so very excited thank you for your wonderful advice
    12-01-2013 01:56 AM
62 123
