Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By Evo4g
    a tired smile's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus froze. Any way to hard reset or power off?
    For some reason, my Nexus 7 froze on the homescreen. Right now, it's just stuck in a state where the screen is dimly lit and won't turn off. I tried to power it off by holding down the sleep/wake button, but it isn't working. Any way to force it to power off or hard reset? Or am I stuck waiting for the battery to run out?
  2. #2
    Evo4g's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus froze. Any way to hard reset or power off?
    try holding power button for at least 10 sec.
    pgmann likes this.
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Default
    Quote Originally Posted by Evo4g View Post
    This. Just hold it until it powers down.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Strangely enough, it shut off by itself. Still not sure what happened. Thanks though!
  5. #5
    grooks's Avatar
    Posts
    Global Posts
    491 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had a similar problem last night. I am running Apex Launcher so I can get my homescreen in landscape mode and initially thought that was what caused the problem.
    The power button for 10 sec was able to force a reboot.
  6. #6
    debbiedarline's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your idea worked great! My husband's three week old Nexus 7 tablet had a black screen and wouldn't turn on. I tried your idea and after 12 seconds - the screen lit back up! Thanks so much for the suggestion.
  7. #7
    RALIR's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had just unlocked my Nexus 7 yesterday to be able to use Stick Mount, along with OTG. Everything was fine.
    Today I tried Type Fresh to install some Indian Fonts (Tamil) on it. I tried by backing up current fonts from Nexus 7 and adding the new fonts to the backed-up folder and then tried to restore the font files. At the end of the process Type Fresh started th rebooting process and got hung up. When I tried to reboot, Nexus would not reboot. The Google text comes up and then switches to flashing the colorful letter "X", but no further. Anybody help with this mess I have gotten into?
    Thank you.
    RaliR
  8. #8
    RALIR's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Everybody,
    Thanks to the WugFresh Root Tool Kit, I am able to get back in business. I had just gotten rooted and unlocked yesterday, but unfortunately I did not think to backup because i was still tooling around. So I still have quite a bit of recovery to do.
    By pressing power, vol+ and vol- buttons together, I was able to boot to the Android Recovery step and the Root Tool Kit did the rest.
    Thank you all.
    Regards
    RaliR
  9. #9
    Shilohcane's Avatar
    Posts
    Global Posts
    1,313 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My N7 was working great since when they first shipped. It did freeze up on a reboot trying to delete the game Six Shooter. After a hour trying to fix it I held the power button for 10 seconds and it then finished the reboot. I was ready to send it back to be fixed till I read this thread.
  10. #10
    emmerson2013's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wink Re: Nexus froze. Any way to hard reset or power off?
    I've just been reviewing a number of different forum solutions as my nexus 7 wouldn't power up. I had tried pressing buttons for all recommended times and sequences but nothing was working. Took the back off and noticed battery connection was not in properly. Repositioned the battery and reinserted the connect, voila.... Powered up fine. On charge now. While not ideal problem, love that I could fix this myself without having to take to a repair shop.
  11. #11
    theresistance's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have made a tutorial on how to fix the problem it is here:
  12. #12
    Ben Price's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i know it seems simple, but this really helped. Thank you!
  13. #13
    gill welsh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks so much, worked 100%
  14. #14
    Judy Ann Siban's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my Nexus 5 froze on the homescreen. Right now, it's just stuck in a state where the screen is dimly lit and won't turn off. I tried to power it off by holding down the sleep/wake button, but it isn't working. Any way to force it to power off or hard reset? Or am I stuck waiting for the battery to run out? help
  15. #15
    Legobricke's Avatar
    Posts
    Global Posts
    554 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Press and hold power for thirty seconds... That should do it.
  16. #16
    Goldwolf26's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Red face Re: Nexus froze. Any way to hard reset or power off?
    Thank u good sir
  17. #17
    Sware A's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The ten seconds hold worked!! thanks
  18. #18
    PerryPing's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same, it happened to me too. While I'm watching YouTube, it just turned paused then froze. So I decided to click power button to sleep then click again to awake, it was all froze and black light, also touching screen is not working. I kept hold power button to turn it "POWER OFF." Then I turned it back on, It kept froze after few minutes. I was so mad. I need someone help me to fix it. I have no idea how to do it. I tried to find other site the way to fix it but there's none of them help me. Anyone have an ideas? Please reply me this comment below or EMAIL to (Email address removed by Moderator)Please don't spam my email.
    Thank you,
    Perry Ping
  19. #19
    dpham00's Avatar
    Posts
    Global Posts
    24,795 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Mod Note,please do not post your email address on this public forum
