My almost 2-week-old C80 has zero visible defects. I suspect in any product that in all of the manufacturing series the percentage of defects is very small. As the product matures, manufacturing issues decline. Satisfied people comment far less than unhappy customers, so initially we see more reports of issues and they get amplified, especially if expectations of the product are high.
Google's return policy, if you bought it from them, doesn't have to do with the warranty, though. It's just a short term return policy that I think they call buyer's remorse, similar to most retailers. I think their policy gives you a 15 day return window, whereas Staples, Best Buy, etc. usually have 30 day policies. After the return period is over, you'll have to deal with the warranty process through Asus, which means you'd be without your N7 for a few weeks.
Yeah. I agree that there are probably some perfect units out there. I'm just one of those people who has had 3 different ones each with the same defect to some degree.
I preordered my Nexus 7 from Google Play and they are still handling my warranty requests directly. Haven't had to deal with ASUS. I'm under the impression Google Play customers won't ever have to deal with ASUS.
Hehhehheh was a this name-brand PC named Dell? My $1000 Dell laptop died within the first hour of use. Then the replacement unit's motherboard died a few months after so it had to be replaced. Then the fan stopped working, causing it to overheat within minutes (coating on bottom melted/chipped away) . Then it finally died a month out of warranty.I recently had a client have a 50 percent failure rate on motherboards from a name-brand PC manufacturer.
I think the real issue is that the Nexus 7 has had bad batches.
How do you find out what cxx you have? I got mine like day 1 at staples so I think mine is a 40c (as per the about).
No problems as of yet screen wise or anything else really.
