1. dmac45067's Avatar
    Somehow I've gotten my Nexus 7 in some kind of accessability demo mode where I cannot control it. If I try to go to home or anything it won't let me.
    Everything has a yellow box around it and everytime I try to click/touch, like the back button or home button, it just makes a click sound. I can't get
    back to settings or anything. HOW DO I Get out of this! Thanks
    10-25-2012 11:52 AM
  2. phonohead's Avatar
    Try to turn the Nexus off, then holds the volume down (or up) button while turning it on again. This should present you with a boot loader, where I believe you can choose to boot normally, i.e. not accessibility mode.
    10-25-2012 11:59 AM
  3. dmac45067's Avatar
    My choices in bootloader are "start" "restart bootloader" "recovery mode" and "power off".
    I tried recovery mode but after it rebooted I was still in the mode where items have a thin yellow line around them
    and I can't get out of it. I can't get to settings to turn this off! Nothing will let me swipe.
    10-25-2012 12:18 PM
  4. phonohead's Avatar
    Try holding 3 fingers, at the same time, on the touch screen. It should cancel accessibility mode.
    Reference: https://groups.google.com/forum/m/?f...ee/P8toFmEkPu0
    10-25-2012 12:28 PM
  5. MJKearney's Avatar
    Call Google support at 855-836-3987.
    10-25-2012 12:30 PM
  6. dmac45067's Avatar
    Okay. Google support got it resolved. Thanks for the help. I must say - I was very impressed with google help.
    Answered the phone right away and quickly got me back on track. Well done Google!
    MJKearney likes this.
    10-25-2012 12:51 PM
  7. MJKearney's Avatar
    You're welcome! Yes, it's funny how many posts I read here where I think to myself, "Just call Google." Of course, the forums are a good resource and many people here are very helpful and knowledgeable, but sometimes it's easier to just call the people who built the thing (or whose software runs it)!
    10-25-2012 01:27 PM
  8. mr_nobody's Avatar
    Can you say what they had you do? Would be useful for future visitors...
    10-25-2012 01:35 PM
  9. jonatankarter's Avatar
    Totally! I'm having that issue right now!
    04-20-2013 11:59 AM
  10. kwiksal's Avatar
    ,,yes I had the same problem, I called the number, Here is the solution, Get to the settings page and use two fingers to scroll down to the accessibility>talk back>touch and hold>tap twice hold,> lift ?do the same tap twice and hold lift, on the upper right slide off button, hope this helps, if not call the number,,
    mr_nobody and Mart Thurs like this.
    07-17-2013 05:24 PM
  11. scouminou's Avatar
    Thanks a lot, it works for me also. Very helpfull.
    01-09-2015 02:06 PM
  1. Help Stuck In FASTBOOT MODE
    By lostmarine in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 12-07-2015, 01:31 PM
  2. Help! Stuck in downloading mode
    By Shakedk in forum General Help and How To
    Last Post: 02-18-2012, 08:40 PM
  3. Help. Stuck in USB mode
    By fej180 in forum HP Touchpad
    Last Post: 10-27-2011, 01:40 AM
  4. Help - Stuck in Emergency Mode After LG Updater Failed
    By Chazzum in forum T-Mobile Optimus T
    Last Post: 09-23-2011, 10:51 AM
  5. HELP!! stuck in boot mode
    By daryl6784 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 10-02-2010, 08:51 AM
