Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 153
Like Tree7Likes
  1. #76
    lilcutiedest's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: Tablet won't turn on - HELP!
    I have an hisense tabelt and its a small crack atthe bottom of it, and now it won't turn on!!! I need help... Please... Or let me know if you want to buy it so i can use the money to buy another one.
  2. #77
    Franklen Augustave's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Tablet won't turn on - HELP!
    My Lenovo tablet turns on sometimes and then shutdown and wont open again can you help?
  3. #78
    cowboys2000's Avatar
    Posts
    Global Posts
    149 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Update:
    I sent the tablet to ASUS in Grapevine Texas. Shipped Insured 2 day air. USPS has verified it was delivered. Asus, still does not show a status. I have called once a day the last 4 days and each day they say they will have a supervisor call me back with an update.
    I am in Houston, and ASUS is near Dallas. I "was" in the market for a 2nd and 3rd Nexus tablet but not anymore. Very poor customer support and information.
    Updated: After holding 58 minutes, the supervisor could only tell me the same information the last representative said. NOTHING. Not showing received on their end (good thing it is insured) and no status either.
    I would not be surpised if the tablet arrives back at my house BEFORE they update their systems.
  4. #79
    achu aswanth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i'm also facing the same problem. while i was charging with a different charger it was heaten up and afterwards not turning on . if some one faced the same problem piz help me. i'm totally confused it's been two days
  5. #80
    Posts
    Global Posts
    149 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well,
    At least the status was updated on 9/9/2013 to received........I called on 9/11/13 and they did not have an update and was told that it is being worked on and that it was "just" received 9/9/13...despite verifying it was received 8/26/2013.
    I have talked to others and it appears that the best way to buy this tablet is directly via the Play Store. Why? I know at least 2 people who experienced similar issues with their Nexus Tablets, they called, they sent them in and Google sent them replacement tablets within 3 business days.
    When/If I buy another Nexus tablet (Asus or otherwise), it will be directly from the Play Store!
  6. #81
    Michael Dahling's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Re: Tablet won't turn on - HELP!
    i am having the same problem. and I just got my tablet yesterday. it seemed to be working just fine yesterday. I allowed the battery to die completely before charger it and it doesn't finish starting. Like you it makes it to the "Android" screen and then doesn't go further then that.
  7. #82
    Posts
    Global Posts
    149 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would the taet and try another.
    Sent from my SCH-I535 using Tapatalk 4
  8. #83
    lmvine's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I sent my wife's tablet to ASUS in Grapevine Texas. Shipped Insured 2 day air. After 20 days from receipt it is back & same problem. Locks up, slightly different than before. I can get it to reboot by holding the power & vol down.
    ASUS CS said they have 3 month warranty on repairs.
  9. #84
    Remart Robles's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mine when i start it does turn on but the android robot just keep on flying it just cant go to the window pls help tnx.
  10. #85
    hrvoje fejer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my tablet was empty and i connect it to my laptop,now it wont start,he just write android on screen and stais that way for a wile and shuts down,what shoud i do?
  11. #86
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    same problem i have
  12. #87
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i think ill take it for a repair,what else
  13. #88
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i think they all have a ****y battery or a program error
  14. #89
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    its crazy that we all have a same problem,i think all tablets have an error on it,im from croatia,it means tablets around the world are ****ed up
  15. #90
    Annya Dontmesswiththepotassium James's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help..
    Um, when I was using it, it turned off for some reason. I try turning it on, but that didn't work, or 10 seconds. WHAT I DO?!?!? my mum needs to use it as well and I can't tell her that it don't turn on?! she won't buy me another one so please help
  16. #91
    Ralph Daniel Yturralde's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    im using microdigit7 and may tablet wont turn on..but im using it last night then when i woke up this morning it just turn off and wont turn on.....plzz elp meee
  17. #92
    Reskill35's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, if you have sd card try to remove it and open it again. I hope it helps...
  18. #93
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Please help! I charged it overnight and this morning, I took off my charger and it was up to 80% and I was using it until it blacked out in my hands! Please help! I didn't drop of spill or (anything to break it) it! I appreciate it!
  19. #94
    anon(8222103)'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having the same problem I've got an android tablet and it's not turning on I've had it since May and it's been working fine, no problems. Until I broke my charger then I got a new charger about 20 days later and the red/sometimes green light flashes but it doesn't turn on I also tried holding the power button for 10 seconds nor did that work.
    If anyone knows, reply back, please?
  20. #95
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    did you solve this problem, mine's exactly the same but the light is also green, as well as red
  21. #96
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I broke my charger as well, so I use my mom's phone charger. I was using it last night and this morning I took it off the charger. Then, I used it before boom, it turned off! what I do?? I tried EVERYTHING!!
  22. #97
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got this tablet on my birthday and I had it since November!! I dont get it!!! I DONT! Is it the update or charger, battery????
  23. #98
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Anushae Filza View Post
    Yes. I got my tablet on my birthday and It worked until November!! I don't get it! Is it the battery, power, update, charger???! Please! there's got to be a easy way to get it on! my mum's gonna be angry with me soon
    anon(8222103) likes this.
  24. #99
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine's not working and I've tried pushing the power button for time and it's been charging for about 2 days, really need to fix it, can someone help, please? It was working perfectly fine before this?!?!
  25. #100
    keilflex's Avatar
    Posts
    Global Posts
    243 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    did u ever find the answer to ur problem. its same one i have.^^^^
  1. My Xoom2 won't turn on! HELP!! D:
    By WhateverSofia in forum Motorola Xoom 2
    Last Post: 03-24-2016, 12:02 PM
  2. My Droid X won't turn on! Help! :(
    By AndroidGirlfriend in forum Motorola Droid X
    Last Post: 12-26-2013, 12:49 PM
  3. Droid 2- won't turn on or charge- help?
    By CourtneyParke in forum General Help and How To
    Last Post: 02-27-2013, 09:00 PM
  4. Screen won't turn on, help!
    By beiermb in forum Verizon Droid Incredible
    Last Post: 05-13-2011, 12:52 PM
  5. G1 won't turn on! Help!
    By ALFRITO in forum T-Mobile G1
    Last Post: 09-26-2010, 09:13 AM
