Results 1 to 7 of 7
    Red Rox's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can't get Nexus 7 to do Addition with Voice
    According to the Nexus 7 Guide, I should be able to speak into Google search from the home screen and get my Nexus to add. For instance "Add 3 plus 4". When I do this, the text that comes up in the search box is correct, but it keeps taking me to normal Google web search results instead of actually doing the math. What am I doing wrong? Thanks.
  2. #2
    bigtroutz's Avatar
    Posts
    Global Posts
    525 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can't get Nexus 7 to do Addition with Voice
    erm....not using a calculator app ? say ...is this a trick question ????
    https://play.google.com/store/search...culator&c=apps
  3. #3
    AndroidOsAppsandMore's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just checked Google now. added 3+4 then 5+7. I got an audio response of 7 and 12. Both correct. Seems to be working fine.
    I do not believe the calculator app has the function to use voice commands. Though Google now works well. I would just use it instead.
  4. #4
    bigtroutz's Avatar
    Posts
    Global Posts
    525 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AndroidOsAppsandMore View Post
    hehe, yeh, just making fun of killing bugs with a nuclear device is all.
    Red Rox's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    After playing around with it a bit more, I discovered that saying "Add, 6 plus 7" doesn't work, but just saying "6 plus 7" does. Case closed. Thanks.
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I see what the issue is now. it is likely a speech recognition problem. I tried saying add 6 + 7 and got add 6 foot 7 in the input field. I said add 7 + 6 and it gave me links to office sweat.
    I had not thought to do thing that way you are. Buying saying what is x + x I get an audible answer every time. So buy saying "What is 7 + 6" I receive the audible answer 13. and I tried it the other way around and got 13 for an audible answer.
    So my suggestion is to state things in the form of a what query instead of an add this to this command. Or even using 6 plus 7 as that also gave me a reply of 6 foot 7 the first time I tried that.
  7. #7
    mathelm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Red Rox View Post
    lol, I was gonna say that even with my southern draw, it worked for me. The first voice recondition software to get it right without tons of training from me...
  1. Can not get thru to Live Messenger on Nexus 7
    By bcarteruk in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-30-2012, 02:49 PM
  2. Can't get Netflix to work on rooted Nook Color 1.2 with Honeycomb
    By ahsans in forum Barnes & Noble Nook Color
    Last Post: 08-19-2011, 03:33 PM
  3. Can't get USB to mount with Tiamat 1.1.6
    By treeofliberty in forum Xoom Rooting, ROMs and Hacks
    Last Post: 04-08-2011, 05:59 PM
  4. can't get Iheartradio to work on sprint hero
    By oluvinu in forum HTC Hero
    Last Post: 05-05-2010, 03:36 PM
  5. Can't get alarm to sound
    By bseblman in forum Verizon Droid Incredible
    Last Post: 04-30-2010, 10:25 AM
