1. ExceptforKhloe's Avatar
    I've been having issues, and I've been looking at other thread, it seems to be a relatively common problem. But we don't all have the same symptoms.
    Could it be less an issue of actual battery problems, and more that jellybean is misreporting? I still can't tell if it's hardware or software.
    http://forums.androidcentral.com/goo...-problems.html
    http://forums.androidcentral.com/goo...new-issue.html
    12-21-2012 09:36 PM
  2. jrwatson's Avatar
    Wait until your device dies from lack of battery, and then you'll know. Part of my issue is that the battery declines slowly for the first ~10%, then decreases rapidly after that. But I also have worse than average battery in general, I think. How many hours of web browsing, with screen at min brightness, do you get? Because I get ~5 hours at best, with everything else turned off. It kinda pisses me off that Google advertises 10 hours--unless that's really what I should be getting.
    It doesn't bug me a whole lot since I don't spend like 6 hours on the device, but it's still annoying. I doubt ASUS will do anything about it, I've had battery issues with their laptops in the past and they usually attribute it to user consumption habits. A Google rep once literally told me that it was because I have 4GB of music on the device.
    12-22-2012 12:35 AM
  3. alazose's Avatar
    Im lucky to get 5 hours between charges, and thats with wi-fi, Bluetooth, and GPS turned off. Ive started using reduced brightness, but that takes the joy out of using the device. Im sure the next updated Nexus 7 will have a 5MP back-facing camera, an SD card slot, and a removable battery that lasts for an actual 15 hours. Then we can recharge the drained battery - which will only take 30 minutes for a full charge while we insert the spare. And the price of the unit will not increase. You listening, Google?
    rollandl likes this.
    12-22-2012 03:30 PM
  4. mathelm's Avatar
    Battery is removable....
    Yorker likes this.
    12-22-2012 06:07 PM
  5. jpash549's Avatar
    Impressive didn't know the back would come off that easily. Believe the manufacturers don't want you taking the battery out because they can be dangerous if mishandled.
    12-23-2012 04:04 AM
  6. Slender Troll's Avatar
    If your N7 isn't the 3G version, then this won't apply, but using wifi uses less battery than 3G.
    Correct me if I'm wrong, but I don't think Android was ever designed to have partitioned storage space, so even if the next N7 does have a camera, there most likely won't be a microSD slot.
    Outdated yet Young Motorola Photon 4G
    12-23-2012 06:30 AM
  7. mathelm's Avatar
    Actually I don't think it is that easy. He's just had his off so many times that the hooks are worn down. But the point still stands, the battery is replaceable....
    12-23-2012 10:23 AM
  8. odd1ne's Avatar
    I find my battery to be pretty good, if I browse the net, use a few apps which dont use to much processer I can easilly 10 hours out of it. Play a 3d heavy game like MC4, Dead Space or watch a 720p film it does drain real quick, but thats obvious. Im overall pretty happy.
    12-23-2012 02:03 PM
  9. ExceptforKhloe's Avatar
    Just a quick comment... I was using it while it was on the charger, then took it off.
    So I've been off the charger for 38 minutes using Wi-Fi, and it says it is still charged. This follows an issue over the last two or three weeks where suddenly the battery was draining 25-33% faster regardless of Wi-Fi, Bluetooth, airplane mode, etc
    I have battery monitoring apps and they all say the battery is good, but it has to be misreporting. Wtf?
    12-23-2012 06:59 PM
  10. ExceptforKhloe's Avatar
    The "battery drain" thread is my own post
    12-23-2012 07:00 PM
  11. Kimberlee Ballenger's Avatar
    you know, I am wondering that too.. interesting question
    05-23-2013 03:38 PM
  12. Philshare's Avatar
    I generally use my Nexus 7 about an hour or less most days. Then I let it sit with the display and Wi-Fi off until the next time I need it. What I have found is that the Nexus 7 turns off completely when it gets to something just below 40% in battery status. Most times, I just figured the battery just ran out quickly to 0% but today I turned on the Nexus right after I plugged in the charger and it said there was 36% battery left. If so, there was no reason for it to turn off like it did.
    In total, I would say I get the battery life I would expect as it takes about 3 or 4 days to get there. But that strikes me as misreporting.
    05-25-2013 09:29 AM
  1. Is it possible to charge spare battery without phone?
    By ShanMan in forum Motorola Droid X
    Last Post: 02-13-2014, 01:37 AM
  2. Is it possible to change the battery icon?
    By Japandroid in forum Samsung Galaxy Note 2
    Last Post: 01-23-2013, 10:40 PM
  3. Replies: 2
    Last Post: 10-14-2012, 02:40 PM
  4. is it possible to overcharge the battery?
    By MichaelRM in forum Droid Bionic
    Last Post: 09-12-2011, 03:24 PM
  5. Replies: 2
    Last Post: 11-16-2009, 02:22 PM
