Results 1 to 7 of 7
    Sharon Getchell's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Nexus 7 running with Netgear 600 wireless
    Good morning! My parents just got the Nexus 7 for Christmas along with the Kindle Fire. When they went to Best Buy, the Netgear 600 Wireless was recommended to them, which they bought and installed. The two PCs and the Kindle Fire are showing up on the Netgear Genie but not the Nexus 7. Is there something extra they need to get access for the Nexus 7? Thank you!
  2. #2
    mathelm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 7 running with Netgear 600 wireless
    Do you have the model number? Is it the WNDR3400?
    Either way, try a hard reset on it.
    To clear all data and restore the factory default values:
    Power off and power it back on.
    Use something with a small point, such as a pen, to press the Reset button in and hold it in for at least 5 seconds.
    Continue holding the Reset Button until the LEDs blink twice.
    Release the Reset Button.
    But for less money I would have gone with the more common and better known Cisco - Linksys E2000. It's a actual Gigabit router (1000bps as apposed to 100) and is only $55 bucks at walmart.
    Sharon Getchell likes this.
  3. #3
    mathelm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Found a good article on the nexus 7 and connection issues.
  4. #4
    Microspeed's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sharon Getchell View Post
    Are you sure the the WiFi is turned on on the N7?
  5. #5
    tmaze's Avatar
    Posts
    Global Posts
    120 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In the Wi-Fi settings on the nexus did you tap the plus sign at the top and enter the router info?
    According to my husband the box that comes up with the router SSID and security setting will automatically be filled in, you click save and it will have you enter the router password.
    We have Netgear and once set up it's been fine.
  6. #6
    Raikku's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have Netgear N600 (DGND3700) Dual Band modem/router and I don't have any problems to keep N7 connected to my Wifi. Actually I didn't
    even made any adjustments(of course pw's etc), it just worked straight away.
  7. #7
    PolarBear8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the N600 however I believe you might find that if your hiding the SSID that you will need this app (which I've used for a long time).
    hidden ssid enabler
  1. Running with the Galaxy Nexus and Headphones
    By philosopherisdog in forum Verizon Galaxy Nexus Accessories
    Last Post: 05-27-2012, 12:04 PM
  2. Lightly used GSM Galaxy Nexus running YAKJU & with kickstand case
    By FreakyLocz14 in forum Marketplace Archive
    Last Post: 03-25-2012, 03:40 PM
  3. WTS: AT&T Nexus One with Otterbox Case and Screen Cover
    By potheadhero in forum Marketplace Archive
    Last Post: 08-10-2010, 08:26 AM
  4. FS: T-Mobile Nexus One With Accessories
    By Droid800 in forum Marketplace Archive
    Last Post: 08-08-2010, 11:07 PM
  5. Nexus running 2.2 wifi problems!!!
    By DVNO in forum Google / HTC Nexus One
    Last Post: 06-05-2010, 01:28 AM
