Results 1 to 5 of 5
    pegleg#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery won't fully charge
    In the last few days I noticed that I can't get the charging level above 96%. There doesn't seem to be any discharge problems, and I'm still getting the same usage from the battery. Right now it doesn't present any problems, but I'm worried something is going on. Any ideas?
  2. #2
    mathelm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery won't fully charge
    Long shot, but I assume you're using the original that came with it?
    pegleg#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep, and I'm using the factory charger. It works, it just never charges past 96%.
    pegleg#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Charger must be getting weak..... Motorola Razr Maxx HD charger took it right to 100%. Funny problem though, the Asus charger would go to mid 90's in the normal amount of time.
  5. #5
    jpash549's Avatar
    Posts
    Global Posts
    2,035 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why worry about not being able together over 95%.
    May be that the battery calibration is just a little off.
  1. HTC One V Battery won't fully charge
    By earlofportland in forum HTC One V
    Last Post: 04-02-2015, 04:34 AM
  2. Battery won't fully charge... even after a refurb
    By Philky in forum General Help and How To
    Last Post: 05-11-2012, 10:10 AM
  3. Battery dock not fully charging batteries
    By 1812dave in forum Droid Bionic
    Last Post: 09-25-2011, 12:22 PM
  4. Battery does NOT fully charge
    By skidmark in forum Sprint Nexus S 4G
    Last Post: 05-08-2011, 10:44 PM
  5. 2600 mAh battery won't fully charge?
    By rosariorose9 in forum Verizon Droid Incredible
    Last Post: 07-14-2010, 07:05 PM
