Results 1 to 7 of 7
Like Tree1Likes
    Cremacious's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery won't go past 67%. Help?
    Yesterday I rooted my nexus 7 and did a clean install of smoothrom. Later on I noticed my battery wasn't fully charged even though I had it plugged in for a few hours. The battery was at 67% and won't go past that. I believe it is because I rooted and installed the rom while not being charged 100%. So the device is fully charged but thinks its at 67?
    Now.. how do I go about fixing this? I'm thinking to let it die and recharge to see if it will go to 100, or unroot and return to stock to see if that works. Maybe?
    Any help would be great.
  2. #2
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery won't go past 67%. Help?
    if you are using clockwork mod recovery. there is an option to clear battery stat. try doing that and charge it full
    Cremacious's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I went into clockwork recovery, went to advanced, and the wipe battery stats option wasn't there.
  4. #4
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cremacious View Post
    you seem to know the exact term "wipe battery stat" even though i said clear battery stat!!!
    all recovery has it. not having it would be a lie
    Cremacious's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  6. #6
    Soundtrack to Chaos's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try taking your tablet off for a few hours and then turn it back on. give it like 3 hours off and then turn it on, read the battery percentage, then charge it to its max
    Sent from an orange potato......no, really
  7. #7
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by still1 View Post
    Why would he lie about something like that? Does that make any sense? :thumbdown:
  1. Won't go past the Samsung Logo Screen!! Please Help!!
    By keelon.ellis in forum AT&T Samsung Infuse
    Last Post: 02-17-2014, 01:34 PM
  2. Rooted phone won't go past logo! Help!
    By arielleighbee in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 04-02-2012, 07:34 PM
  3. HELP!! Phone won't go past LG screen!
    By bradmckee in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 09-05-2011, 10:50 PM
  4. HELP! A friend rooted my Evo 4G today and it won't go past intro/turn-on screen!
    By shtaylor1 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 05-17-2011, 02:34 PM
  5. Android won't load past Logo! HELP!
    By carmen89 in forum T-Mobile myTouch 3G
    Last Post: 12-28-2009, 07:52 PM
