Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By gen2010
    Abney Cooper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default nexus 7 4.2.2 updated...STILL NO BLUETOOTH FIX
    Updated my nexus 7 this morning
    Hoping to receive fix for Bluetooth, still not fixed
  2. #2
    talonsmith's Avatar
    Posts
    Global Posts
    150 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: nexus 7 4.2.2 updated...STILL NO BLUETOOTH FIX
    And what is your "bluetooth" problem? A little more info.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bluetooth doesn't even turn on
  4. #4
    StealthTH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ever consider faulty unit?
  5. #5
    Fmrvette's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Abney Cooper View Post
    Maybe you have a defective unit? Bluetooth works fine with mine (connected to a Bluetooth keyboard).
    Regards,
    Jim
  6. #6
    YAYTech's Avatar
    Posts
    Global Posts
    2,287 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No Bluetooth problems here either. I'd be in touch with customer support.
  7. #7
    John R Johnstone's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, it's likely not your unit. It's a known issue. I'm having the same.
  8. #8
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bluetooth works great, for the first time since I bought the N7 right after launch. Before the update music via BT was TERRIBLE. tons of drop outs. The worst was when I'd do anything with the tablet as music was playing from Pandora, but it also had dropouts with my own music. Since the update, I can go HOURS without a single missed note. Hooray!
  9. #9
    drew_t's Avatar
    Posts
    Global Posts
    120 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    BT dropouts have also been eliminated for me since the 4.2.2 update.
  10. #10
    Allen Salyer's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No dropouts for me since update.Your problem sounds like something other than update.
  11. #11
    MJKearney's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So, do you mean that when you go to Settings and tap the switch to turn on Bluetooth, the switch goes to the on position for a split second, then springs back to the off position? If so, I've had this happen, too.
    I think, but can't verify, that it had something to do with a 3rd party widget (Power Toggles), that lets you place assorted controls like Bluetooth and WiFi on your home screen and notification bar. When I tapped the widget to turn off Bluetooth, then attempted to turn it on again using the normal Nexus 7 settings method, the switch wouldn't stay in the on position. I tried using the widget, and still no luck. I finally rebooted my N7 and everything was back to normal.
    Again, I can't verify that it had to do with the widget, and I don't feel like trying to recreate the problem! But I can verify that I've been in a situation where the Bluetooth switch wouldn't stay in the on position.
  12. #12
    gen2010's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i cannot turn on bt either unless I go to settings, apps, all, go to blue tooth share and clear the data. Then I can turn on the blue tooth without the on off switch going back to the off position. I still have to re pair my keyboard each time which I didn't use to have to do. So every time I want to use my keyboard I have to go through this process.
    nishiko likes this.
  13. #13
    FiZ1point5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same issue: turning the bluetooth on reverts back to "Off" immediately. I've never tried clearing the data, but so far, resetting the Nexus 7 brings Bluetooth back for a little while. However, as soon as I turn it off again, and leave the tablet alone for a few hours, the problem comes back. I'm not even using any power management apps on my Nexus 7 either. I use Juice Defender on my Galaxy Nexus, and it never has this problem.
  14. #14
    smooth3006's Avatar
    Posts
    Global Posts
    1,711 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    4.2.2 on the nexus 7 doesnt impress at all. Very laggy and horrid gpu rendering for me. Cant comment on bluetooth as i dont use it.
  15. #15
    Escapist From LA's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: nexus 7 4.2.2 updated... NO BLUETOOTH FIX (now with v.4.3.0)
    I've been reading this topic and keeping an eye out for others experiences for a couple months now.
    This past week I received the v.4.3.0 update across both of my tablets.
    I have a Blue Ant Z9i bluetooth headset that apparently cannot be paired with either the tablets with the previous v.4.2.2 version or the recent v.4.3.0.
    I set the headset to be discovered in pairing mode, tell the tablet to search for devices, but neither tablet will discover the headset. Headset works fine with my Galaxy 4S phone and my wife's iPhone, so I seriously doubt it's the headset.
  16. #16
    Ronald Gordon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just got off the phone with Zagg customer service because my Zagg Flex Bluetooth keyboard no longer works with my 2012 Nexus 7 tablet after the OS update. The Zagg keyboard works with my older Android OS phone, so it is not the keyboard. Zagg says failure to recognize is a known problem with the latest Android OS.
    Oddly, my first-generation Macintosh aluminum Bluetooth keyboard (the model that uses three AA batteries; the new model only uses two AA batteries and I have not used that version) pairs and is recognized by the updated 2012 Nexus 7.
    Anyway, it's not your peripherals. It's the tablet's operating system in need of a patch.
  17. #17
    Peter Greene's Avatar
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have 4.2.2 on N7 2013. I had no problems using A2DP Bluetooth headphones until the 4.2.2 update. After the update, the bluetooth will stream music to my headphones for anywhere from 5 to 20 minutes then the BT shuts down on the tablet and will not turn back on. I have rebooted and each time it hooks back up immediately only to shut down a while later. It is a very frustrating thing to happen while commuting on public transportation.
  1. Nexus S 4G Price and still no Date
    By justinsaneeeee in forum General News & Discussion
    Last Post: 04-07-2011, 10:19 AM
  2. Still no update?
    By closers7 in forum Google TV
    Last Post: 12-20-2010, 02:50 PM
  3. Still no Android 2.2 update
    By jwehrer in forum Verizon Droid Incredible
    Last Post: 10-10-2010, 08:12 PM
  4. Still no 2.2 update for me
    By tduffysd in forum Motorola Droid X
    Last Post: 09-22-2010, 11:33 AM
  5. Still no Froyo OTA update for my Evo
    By Brademcee in forum HTC EVO 4G
    Last Post: 09-07-2010, 03:39 PM
