1. dougltc's Avatar
    I noticed while indoors recently that my N7 was searching for GPS continuously for over an hour which I assume was draining my battery faster...
    I assumed that it would timeout but it never stopped until I went outside.
    I long-pressed on the notification tray item and selected App Info to see which app was the offending party and found that it was 'system UI' with a jelly bean icon...
    Questions:
    Is there any way to set a timeout or figure out why it is searching for GPS?
    Are there any apps to control this annoying behavior?
    If there isn't a remedy, how do I change the permission to force the system to ask for permission to access the GPS?
    Thanks!
    03-06-2013 08:53 AM
  2. MJKearney's Avatar
    Why not just turn off the GPS? Go to Settings > Location Access > GPS Satellites, and uncheck it. When you have a specific need for GPS when using an app, turn it on again.
    03-06-2013 09:45 AM
  3. GeekMD's Avatar
    Thanks for the suggestion. I have found that turning off the GPS works...
    But does anyone know if this is the expected behavior for a Samsung Galaxy S4 with the latest Android OS...
    06-28-2013 02:10 PM
  4. Darmond Phillips's Avatar
    Hello I need help with my phone I have no sim card in it so this sim card icon is sitting there on my status bar but when I long press it it sends me to the systems UI Q. How can I get that off without messing something up
    08-13-2013 04:29 AM
  1. How-To repair your bootloader after using the 2.1 RUU
    By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 01-31-2014, 06:08 AM
  2. Replies: 1
    Last Post: 11-09-2012, 08:35 AM
  3. So what's the deal using the GPS?
    By expidia in forum Verizon Droid Charge
    Last Post: 06-28-2011, 07:14 AM
  4. EVO 4G - how's the GPS, and can it USB tether?
    By dburr in forum HTC EVO 4G
    Last Post: 06-04-2010, 02:20 PM
  5. How do you type "?" using the physical keyboard?
    By Fat Fingers in forum Motorola Droid
    Last Post: 02-20-2010, 05:32 PM
